04-29-2024 19:32
04-29-2024 19:32
Well. It’s very sad. The end of the Fitbit Zip community has came. I had great memories with my Zip and I’m sure others have too! Some might even still be using a Zip or just found their old Zip from a while ago. I’d also like to share a common problem I’ve had with my Zip. It doesn’t turn on without firm pressure on the battery. To fix this, bend the TIP of the positive terminal up and pull the negative terminal out. That’s all I have to say now, bye Fitbit Zip and other communities.
04-29-2024 21:17
04-29-2024 21:17
Hey @mcchin we're still here. You can post in the Android or iOS area or even some of the more social type forum areas. Got a friend still with the same Zip from seven years ago, I think. They also have one stashed in a drawer should the first one begin to show signs of dying.
