01-22-2019
17:58
07:04
YojanaFitbit
01-22-2019
17:58
07:04
YojanaFitbit
I replaced my battery and now the time is incorrect and in the middle of the afternoon it reset. How do I set the time to get this to work right again?
Moderator edit: Updated subject for clarity.
How you doing @CherieT? Welcome my friend! ![]()
Thanks for sharing your experience with Fitbit Zip and for trying those steps. Next time you notice that issue, check if the little metal contacts on the back of of your Zip are well positioned; you can check some helpful information in this post. Also, check if the back is clean and that the battery door is not broken or loose. Other tips:
Hope this helps.
