03-25-2016 10:28 - edited 10-12-2017 07:53
Is your Fitbit tracker lost? Here are some tips you can follow to find it:
- Check your dashboard to see the last time your tracker synced. If it synced recently, it means that it is within 15-20 feet of a computer with the Fitbit Connect software installed and a dongle plugged in or your mobile device.
- Look near your laundry. Many people who clip their tracker onto clothing find that it ends up in the dirty clothes pile.
- If you've paired your Fitbit tracker with a mobile device, you can take that device to the area where your tracker may have been lost and watch for it to sync. This may help you to pinpoint its location.
If you don't find your tracker in the next 24-48 hours, feel free to contact our Support Team.
Good luck finding your Fitbit!
03-25-2016 11:07
03-25-2016 11:07
Here are a couple of other ideas that have crossed my mind...
If you're on Windows Phone (and sync your Fitbit), the Gadgets app will tell you when and where it was last connected, like this:
If you tap on it, it'll even give you directions to that location. And you can do this with any bluetooth device, so if you were wondering if you left your bluetooth headset at work, this will help you out.
Also, you can cross-reference the last sync time listed on your dashboard and your activity graph (both steps and flights of stairs). How this may help you:
Just some ideas.
Frank | Washington, USA
Fitbit One, Ionic, Charge 2, Alta HR, Blaze, Surge, Flex, Flex 2, Zip, Ultra, Flyer, Aria, Aria 2 - Windows 10, Windows Phone
03-25-2016 11:07
03-25-2016 11:07
When the tracker is somewhere on the floor.. it's also possible when having a panty.. to use a vacuum cleaner.. slide the panty over the vacuum cleaner part.. any objects stick with the force to the panty, not going inside the vacuum cleaner..
Hope everyone who lost their 'buddy' is able to find back.
