05-11-2020 16:57
05-11-2020 16:57
My Zip Tracker goes from 100% battery to 0% battery without any warning and then I loose my steps for the day. I have tried getting data as suggested on computer, iphone and tablet -- all turning bluetooth off and then back on. This has happened to me 3 times this year --- it is very frustrating as even when I manually enter steps, it is not reflected in various weekly challenges I participate in. Please fit the data transfer issue with low battery, as well as the low battery indicator to be accurate. thanks!
05-16-2020 11:22
05-16-2020 11:22
Have you cleaned the contacts with isopropyl alcohol, @Mngal2001?
Also check the contacts
As for the app it will only know the battery level during the last successful sync
