05-06-2016 21:25
05-06-2016 21:25
06-30-2016 13:29
06-30-2016 13:29
I received my fitbit zip on fathers day(11 days ago). While just walking around at work it fell out. I tried everything I could to find it,but nothing. Customer service offered me a 25% discount on a new one. Reading the forum posts this seems to be an issue for quite some time. One would think they would have solved this before now. Offering to give a 25% discount to buy the same piece of garbage that I just lost is a waste of my time and money. I will definitely tell people about this experience so they won't make the same mistake.
10-13-2016 06:00
10-13-2016 06:00
05-07-2016 06:43
06-30-2016 13:29
06-30-2016 13:29
07-01-2016 05:34
07-01-2016 05:34
07-05-2016 08:14
07-05-2016 08:14
Hey, @LEgan! I'm so glad to hear that it was at your daughter's house. Thanks so much for you feedback, we are always trying to improve our products based on it.
I hope to see you around more often, please make sure to check out our cool discussions board and share with the Fitbit family!
10-13-2016 06:00
10-13-2016 06:00
10-14-2016 09:37
10-14-2016 09:37
Hey, @JaniHennes! It is nice to see you. I'm sorry to hear about your past experiences. However I'm glad to see that you are creative and have great ideas, now all you have to do is make it look pretty, I'm sure you can do it!
I would like to see you around a little more, make sure to check out our cool Discussions board.
01-11-2017 16:34
01-11-2017 16:34
Is there a way to track?
01-12-2017 06:25
01-12-2017 06:25
You can track through the app on your phone or using the usb device on yyour computer. the zip fit will store the information for 7 days between "syncs". I hope this helps.
01-12-2017 06:27
01-12-2017 06:27
I just realized you probably meant track the device itself.
01-12-2017 06:57
01-12-2017 06:57
after I lost mine in Disney World I bought a tile that I have attached to my zip using a dot of epoxy. I cut a small hole in the clip to allow the chain to hang and the zip fit can still pop out enough to change the battery.
01-15-2017 10:17
01-15-2017 10:17
I ended up getting a "leash" like one uses for a flash drive to connect to my Zip. The string end goes around the clip on the Zip in the holder, and I hook the locking clip part of the leash to my pants. The Zip goes in my pocket, and it keeps it from falling off and getting lost.
01-27-2017 09:29 - edited 01-27-2017 09:46
Hi there, @Monica3472, @b_bam, @stepbystep39! It is nice to see new faces around. The only way to track your Fitbit would be to try to sync it and walk around the places you think it might be. If it doesn't then there is no other way because it does not have GPS or anything like that. However you can contact our Customer Support team and check your available options with them.
Also, thank you for sharing your ideas of keeping the Fitbit in place and secure, sounds very cool, if you could share pictures would be nice!
Have a nice weekend!
