04-02-2014 15:10 - last edited on 12-03-2015 17:23 by TarinFitbit
Ever since I replaced my battery my fitbit doesn't work. Any ideas?
04-04-2014 14:01
04-04-2014 14:01
Are you positive the battery is not dead? Did you buy more than one battery?
If not you might want to contact support.
04-04-2014 12:59
04-04-2014 12:59
@tsamms wrote:Ever since I replaced my battery my fitbit doesn't work. Any ideas?
Reset your Zip by:
Make sure the battery is in correctly. When I changed batteries I didn't have in just right and I had to do the above.
Hope that helps.
04-04-2014 13:29
04-04-2014 13:29
04-04-2014 14:01
04-04-2014 14:01
04-04-2014 14:06
04-04-2014 14:06
04-07-2014 21:46
04-07-2014 21:46
Did you sort this out? I've just had the same problem. i bought a new CR2025 battery as per the email but it doesn't work. i even took the battery back because i thought it might be faulty. Any ideas?
04-23-2015 07:47
04-23-2015 07:47
I'm having trouble with my zip battery door closing tightly enough to make a good connection. Try pressing hard on the battery and see if your zip turns on. If it does, then you might be having the same problem as me. I'm planning on contacting customer support directly about it because it seems like a hardware issue.
01-08-2016 08:48
01-08-2016 08:48
I just had to reply to this as I searched for this same problem. For those of you out there that are having the same problem...don't forget to take off the batteries protective paper before inserting...like I did..:-( Works great now that I did that. haha.
01-12-2016 07:15
01-12-2016 07:15
Hey hey hey @lelk, it's nice to see you around! It's good to know that your Zip is working great now! Thanks for sharing this tip!
Have you checked our Discussions board? There you can share your story, find some fitness tips, recipes and more! Give it a look!
See you around, enjoy your 2016!
Was this what you were looking for? Vote for it and mark it as an Accepted Solution!
01-12-2016 13:07
01-12-2016 13:07
Many thanks for that. I removed the protective paper on the battery and my fitbit zip works again.
Thank you so much!
05-04-2016 09:48
05-04-2016 09:48
I have noticed the battery terminal on the side will sometimes get bent back. You can get a small object in there and bend it back out and it will make connection with the battery again.
05-05-2016 07:45
05-05-2016 07:45
Hey hey @076252 thanks for the tip! In case you feel that the battery contact is not longer working properly, I recommend contacting support so they can evaluate your case and options! We want you to have a great Fitbit experience.
See you around!
05-05-2016 07:45
05-05-2016 07:45
See you around!
05-12-2016 07:29
05-12-2016 07:29
My fitbit zip also did not appear to be working after changing the battery.
It must have been a bad connection because it did work when I manually pressed the battery down hard.
To keep it 'pushed down' I put a penny on top of the battery and was able to close it. Seems to be working fine, and it's tough to beat a 1 cent fix.
05-15-2016 07:03
05-15-2016 07:03
Hey @brdaverick welcome to the Forums! Sometimes the side spring may be bent as a result of improper battery insertion or pressure being applied to the back housing. Please verify that there is proper contact between the battery and the battery contacts inside your Zip tracker. You can do this by opening the battery door of your Zip, removing your battery, and ensuring that the silver battery tab located in the lower right half of your tracker is flush with the white box outline in the tracker housing.
If the issue persists, I recommend contacting support so they can further investigate and evaluate your case. I'm sure they will be glad to help.
See you around!
05-17-2016 11:28
05-17-2016 11:28
Looks like alot of people are having problems with their Zip. Mom just siad she put a new batery in and hers will not work. Said everything seems to be in place as far as the electronics are concerned. Any ideas....?
05-17-2016 13:27
05-17-2016 13:27
Hey, in this case I recommend contacting support so they can investigate and evaluate her options. We appreciate your feedback!
See you around!
05-21-2016 12:55
05-21-2016 12:55
It was the paper. Duh... It's working fine now.
05-23-2016 10:02
05-23-2016 10:02
Welcome to the forums @TJ16! I'm glad to hear you were able to sort out the problem with your Zip.
If you ever encounter anything odd, do not hesitate in letting us know.
Happy stepping!
PS: Have you checked our Discussion Boards? They are full of fellow fitbitters like you
05-24-2016 08:12
05-24-2016 08:12
Follwed instructions provided and it is still not working. Not syncing at all and changed battery two weeks ago.
