04-02-2014 15:10 - last edited on 12-03-2015 17:23 by TarinFitbit
Ever since I replaced my battery my fitbit doesn't work. Any ideas?
01-18-2019 08:20
01-18-2019 08:20
Hahaha! Thank you - I did the same thing 🙂
08-05-2020 06:02
08-05-2020 06:02
THANK YOU!!!! Your suggestion about the tiny battery terminal on the lower inside was my problem! I had dropped my Fitbit Zip and could not get it to restart - even with new battery. Not even a scratch on it but seemed to be dead. Another person posted a suggestion to press in the battery without the back on and when doing that I could see that the screen display came on!!! But it didn't stay on (with back piece reinserted) until I very slightly pulled out that metal terminal. Then I could put the back on again and it is working perfectly and can now resync.
08-05-2020 18:45
08-05-2020 18:45
08-05-2020 19:15
08-05-2020 19:15
08-06-2020 06:27
08-06-2020 06:27
08-06-2020 11:32
08-06-2020 11:32
06-15-2023 12:39
06-15-2023 12:39
I’m having the same issue has you
