06-30-2017
08:26
19:57
LucyAP
06-30-2017
08:26
19:57
LucyAP
My Zip is just over 4 years old. Recently it stopped tracking calories. It also is sending the message that the battery is low and then the it is OK and then it is low and then it is OK. The battery is only 6 weeks old. I am wondering if i should just buy a new Zip
Best Answer06-30-2017 19:56
06-30-2017 19:56
Nice to see you here @schmidtfrau! This sounds odd. To ensure that your Zip is working as it should, please restart it.
Also, to check that your app is displaying the correct information log out from your app, and reboot your phone. Once your phone is up, log back in.
If this doesn't help, please take an screenshot of your Dashboard. And make sure that your have all your tiles enabled.
Keep me posted with the outcome! 😉
Best Answer07-01-2017 12:04
07-01-2017 12:04
I did all the things you said to do...The calories tile is not hidden on my dashboard, but i still don't get it on my device. The battery notification is still fluctuating from low to full and back again...
Best Answer07-03-2017 10:17
07-03-2017 10:17
Thanks for the update @schmidtfrau! This is a non expected behavior. To better understand the issue you are experiencing, can you please attach an screenshot of your Dashboard?
In the meantime, check your Online Dashboard to see if it's displaying your calories and the correct battery level.
I look forward for your reply!
Best Answer07-04-2017 12:00
07-04-2017 12:00
Mine says "battery low" often even when it's a new battery. Try taking the battery out and leaving it out for 10-20 seconds and this should help. Also, I do notice that the batteries run down sooner if I sync often.
Good luck!
Best Answer07-10-2017 13:44
07-10-2017 13:44
