02-06-2016 18:54
02-06-2016 18:54
05:40
09:46
02-07-2016
05:40
09:46
It's great to see you around the forums @lbilowus! Your Zip does not have the physical capacity to make a sound or vibrate when you've reached your goal; however, you'll see cute little faces called Easter Eggs that will smile or frown depending on your progress for the day. ![]()
Hope this helps! Let me know if you have any questions.
05:40
09:46
02-07-2016
05:40
09:46
Best Answer02-07-2016 09:49
02-07-2016 09:49
That's a bummer. I just find it hard to see what my steps are while I'm in motion, like the treadmill. Some days, as we all have experienced, I just want to stop my workout once I reach my daily goal. Thanks for the response!
10:50
09:45
02-07-2016
10:50
09:45
I'm glad to help @lbilowus! I know you wish to get the "celebratory dance" on your Zip; but I can assure you that is a pleasant surprise when you are working out and as soon as you check your Zip you are over your steps! ![]()
Do not hesitate in letting me know if you have any questions!
PS: Have you checked our Discussion boards? They are full of fellow fitbitters like you ![]()
