05-18-2017 07:17 - last edited on 07-04-2017 19:48 by LucyAP
05-18-2017 07:19
05-18-2017 07:19
Any body having in trouble ? I did OVER 10,000 steps yesterday hate to loose them.
05-18-2017 08:59
05-18-2017 08:59
happens to me all the time. about ready to throw this thing away.
05-18-2017 09:52
05-18-2017 09:52
I am having the same problem. Last time synced May 17th at 6:30PM. I have reinstalled and followed all the trouble shooting instructions and it still won't sync.
05-19-2017 05:55
05-19-2017 05:55
I am having issues myself. I downloaded the new update to my iMac this morning and I cannot get it to sync up to move my info from the Zip to online.
05-19-2017 18:11
05-19-2017 18:11
You won't lose them; the zip records the past seven days.
05-19-2017 18:37
05-19-2017 18:37
05-19-2017 18:40
05-19-2017 18:40
05-19-2017 19:52
05-19-2017 19:52
Thanks for taking a break from stepping to visit the Community @lejones, @mquar, @debates, @Strahd9, and @Natalie39! To make sure that your Zip is working as expected, please restart it. Also, you can log out from the Fitbit app or your Fitbit account and reboot your device. Once your device is up, log back in.
If this doesn't work, you can try these helpful tips to sync your tracker again.
Good luck, keep me posted! 😉
07-02-2017 13:53
07-02-2017 13:53
Well, my fitbit is at it again. I had nearly 8000 steps. Then I synced and it shows less than 5000. This happens nearly every day and I do restart the device. It does not help. I really wish this product worked better as I do not want to wear a device on my wrist. I want to continue using fitbit as I receive points at my gym for getting my steps. But perhaps it just isn't worth it. I'm beginning to believe it is just a very poorly designed product.
07-03-2017 10:30
07-03-2017 10:30
Thanks for the update @mquar! In this case, I would recommend checking the metal spring inside the Zip's battery compartment. Sometimes your tracker will have battery issues when this is bent. Here is a picture of how it should look like:
If after doing this you continue to experience the same, please let me know I'd love to help you to get back on track.
07-04-2017 13:04
07-04-2017 13:04
07-04-2017 13:11
07-04-2017 13:11
07-09-2017 04:56
07-09-2017 04:56
This happens to me sometimes. I've found deleting the Android app and reinstall has always fixed it. I do have overall problems with how long it takes to sync if I ask it to sync, like after a challenge. Sometimes I will click the all day sync on or off and it will then sync.
07-09-2017 05:55
07-09-2017 05:55
07-11-2017 06:42
07-11-2017 06:42
same here...brand new just bought and set up and I swear it's Fitbit....2nd fitbit and still not impressed!
07-13-2017 15:31
07-13-2017 15:31
Where have all the steps gone?
07-13-2017 15:32
07-13-2017 15:32
Why doesn't the moderator respond?
07-13-2017 15:33
07-13-2017 15:33
I'll probably do the same thing.
07-13-2017 15:52
07-13-2017 15:52
