It's good to see you in the Community @Skhicks! Your calories, as well as all your other information, resets to zero each night at midnight. So if you're out an about at midnight, your calorie burn will go back to zero and start the count all over again. Just a heads up that your data is stored in your Zip for 7 days so even if your tracker resets, you'll be able to sync and update your Dashboard with the saved data.
I hope this helps!
