08-04-2017 05:04
08-04-2017 05:04
I have Fit Bit installed on computer and this morning synced with my device, but on Dashboard shows no device paired or any updates from yesterday.
Best Answer08-05-2017 08:25
08-05-2017 08:25
Thanks for stopping by @KELLEY0703! This sounds odd. Please try setting up your tracker as a new device. Also, please make sure that you are using the email account you used to register with the Community forums.
I hope this helps, keep me posted! 🙂
08-07-2017 04:39
08-07-2017 04:39
I just did this again this morning and everything showed synced then once again I go back to the Dashboard page and shows me "device not paired". I have no clue what else to do. I've installed the Fit Bit on my computer, set up Bit again and this morning it worked then when I went back in to the Dashboard not paired again. This is getting very frustrating.
Best Answer08-07-2017 19:22
08-07-2017 19:22
Thanks for the reply @KELLEY0703! It sounds like you are using different email accounts. To make sure which one you are using, log out from your app and go to Fitbit.com/settings/profile to see the email you are using on your computer. I hope this helps.
Keep me posted! 🙂
