04-02-2018
09:58
14:32
LucyAP
04-02-2018
09:58
14:32
LucyAP
I can not setup a zip with the newest Fitbit Connect ver 2.0.2.7030 for Windows 7. The "Which Fitbit tracker are you setting up? " window does not have zip as an option to setup. Please assist. Thanks Jerry.
04-02-2018 14:31
04-02-2018 14:31
Welcome to the Forums @mrjdsmith! I really appreciate that you have shared all information of your app and computer. This sounds odd.
The best in this situation is to uninstall and reinstall the Fitbit Connect software from your PC. To do so, please follow these steps:
Before reinstalling, we recommend you temporarily disable any antivirus or firewall software, as it may interfere with proper installation of Fitbit Connect. You can re-enable your antivirus once the installation is complete.
To reinstall Fitbit Connect, please do the following:
I hope this helps, keep me posted! 😉
04-02-2018 14:45
04-02-2018 14:45
Ive done this several times with tech support and they have said it is a known issue with the newest release. But that does not help me.
The zip is not an option in the selection of the type of fitbit.
04-03-2018 06:57 - edited 04-03-2018 12:56
The easiest work around would be to use a phone or the win 10 app to setup the Zip.
Do you have a compatible phone, or abother option would be to borrow a friend's phone to setup the zip. I'm sure one of your fitbit friends will help you out.
They simply would log out of their account and you log into yours .
Then do an add device
04-03-2018 11:20
04-03-2018 11:20
Awesome suggestions @Rich_Laue! Thanks for the update @mrjdsmith! If after trying what @Rich_Laue kindly suggested you are not able, please let me know so I can be of help.
Catch you later! 🙂
04-10-2018 15:46
04-10-2018 15:46
We have a employee that only has a windows 7 machine and is living in another state, so we can't do that suggestion and just need the Windows Application to work.
Thanks.
Jerry
