03-29-2014 14:33 - last edited on 11-29-2015 09:40 by HelenaFitbit
My fitbit zip battery back will not open. I have used the tool that comes with the Fitbit zip and a quarter to try to open it. It will not open. I have enlisted the help of my daughter and son in law, fitbit owners as well, who say it is unusually tight, and they can't open it either. The only person who has ever been able to open it, are the employees of RadioShack (where I purchased my new battery from).
Has anyone else encountered this? Any ideas to get it to work?
04-24-2017 13:46
04-24-2017 13:46
04-25-2017 02:49
04-25-2017 02:49
04-25-2017 17:45
04-25-2017 17:45
04-30-2017 10:22
04-30-2017 10:22
I pressed down really hard and it opened because it broke a new door not available sigh
04-30-2017 14:10
04-30-2017 14:10
05-01-2017 18:11
05-01-2017 18:11
I just tried what another community member suggested and it worked! To open your Zip battery door, heat the battery door for 30 seconds with a hair dryer. It opened easily and while I had it opened, I cleaned the battery door.
05-02-2017 10:59
05-02-2017 10:59
05-02-2017 10:59
05-02-2017 10:59
05-02-2017 12:07
05-02-2017 12:07
I can't get the battery door to open.
05-03-2017 11:01
05-03-2017 11:01
I used the wee cover from my second fitbit zip different color but it does not show.
all zips in a drawer
now wearing a charge 2.
vjw class of 1965
05-10-2017 18:56
05-10-2017 18:56
Thank you. The hairdryer trick worked perfectly. I heated it for a few seconds and the quarter worked just fine. I had been trying every coin for the last 20 min to try and pry open the back but nothing was working. Thank you thank you
07-17-2017 13:46
07-17-2017 13:46
After struggling to get the battery door open, one tip worked:
I used a hair dryer for about 30 seconds and it opened.
It took a couple of tries, but it worked!
Good tip. Thanks.
09-22-2017 14:03
09-22-2017 14:03
Just picked up my fitbit ZIP - but could not open the battery door. Hair blower on it for a few seconds did the trick!
09-22-2017 14:08
09-22-2017 14:08
My Fitbit was "lost" in a hot closet for a year.
The only way the battery door would open was with the heat from a hair dryer.
10-09-2017 20:35
10-09-2017 20:35
What also works is a hand dryer (hot air).
12-14-2017 00:34
12-14-2017 00:34
I had the same problem... slippery little thing.
After a frustrating few minutes, I slipped the Zip backwards into the clip holder and this made it very easy to grasp. Once I had good hold of it, I could open it without problem.
12-21-2017 12:40
12-21-2017 12:40
Who designed the Fitbit Zip??!! Battery cover doesnt open properly. Do not buy this!
12-21-2017 13:00
12-21-2017 13:00
12-21-2017 21:12 - last edited on 06-14-2018 10:15 by LucyAP
To “unstick” the battery cover, gently use the heat from a hair dryer to “loosen” it.
It works.
Andrea Owad
01-25-2018 08:53
01-25-2018 08:53
30 seconds with hairdryer on high got it to move then had to pry open, but it worked!! Thx for tip!!
