06-17-2015
21:14
10:08
HelenaFitbit
06-17-2015
21:14
10:08
HelenaFitbit
I use a zip so am unable to recharge the battery. Each time I put in a new
battery, it lasts a maximum of 1 month. The present battery was put into
the zip last Monday and by Thursday the zip was indicating that the battery
was almost nil. I followed the suggestions to make sure the toggles were
aligned properly so that the battery sat level and that improved the
battery life a bit but on Tuesday of this week I rec'd another message that
the battery should be replaced.
Ruta
Best Answer11-12-2018 04:00
11-12-2018 04:00
I agree with you 100% bobren.
Although I received a replacement zip, it eventually starting eating batteries too. I gave up and bought a Charge, no issues except for the band coming off. I abused the heck out of my Charge though because of the band design. It popped off my wrist too easily.
Charge 2 is even better! I'm glad they changed the design of the band to a standard watch strap. It stayed on my wrist......until recently. One of the band straps on the Charge 2 keeps popping off. I've had it for almost one year.
11-12-2018 18:35
11-12-2018 18:35
11-16-2018 09:33
11-16-2018 09:33
Hi @xenaFB and @Sunwalker18. thanks for sharing you comments.
Sorry for all inconvenience with your Fitbit trackers but thanks for reporting the recent issues with your Charge 2 band. @CLChing I've requested a new case for you, so you will get a follow up email to see what are the options you have with Fitbit.
@Sunwalker18 Feel free to visit more details about Fitbit Versa in the Versa Board. If you have questions you can let me know or you can post your inquiry there.
Let me know if you have questions about it.
Best Answer11-16-2018 10:18 - edited 11-16-2018 10:18
My second Zip does the same thing...eats batteries fast. I can't decide if the third time will be charm or if I should just give up.
11-16-2018 18:12
11-16-2018 18:12
11-19-2018 06:49
11-19-2018 06:49
I wish Fitbit one was still available. I had to switch to the zip when I couldn’t find a replacement for my old st Fitbit one.
11-20-2018 13:19
11-20-2018 13:19
Hey there @sma1958, @Sunwalker18 and @Armstrongemily, thanks for sharing your comments! ![]()
I appreciate all the effort that you put into solving these issues with your Zip. Maybe you've already tried this, but why don't your open the back of your Zip and clean the place where you put the battery using a cotton swab. Make sure that the little metal piece that makes contact with the battery is not bend or rusty too.
If that doesn't help it will be best to check with our support team.
Please keep me posted.
Best Answer12-08-2018 21:02 - edited 12-08-2018 21:04
I have no idea why this thread is marked as solved, because it obviously is not, even after several years!!!
I have an older zip that still works perfectly except that a new battery will only seem to last a few days. I got fed up with it so got out a brand new one I had around in case I lost my old one. It was okay until it did a firmware update, and now it reads “empty”. I took the battery out and tested it. It read 3.01 volts, and the battery contacts are perfectly fine. I put the battery back in, but it still said it was empty. .... oh look.... now it is fine again, just 20 minutes later!
After several years, isn’t it time you found out what is going wrong and fixed it?
12-11-2018 10:50
12-11-2018 10:50
Hi @JDHav, thanks for sharing your comments.
We usually suggest this workaround since it has worked for a lot of users. Thanks for all the steps that you've tried to fix this. By any chance you're using an Android phone?
I'm very interested in helping you out with this, keep me posted.
Best Answer12-11-2018 16:59
12-11-2018 16:59
12-11-2018 17:50
12-11-2018 17:50
12-12-2018 17:42
12-12-2018 17:42
12-17-2018 08:50
12-17-2018 08:50
Nice to see you again here @JDHav and @Sunwalker18.
Thanks a million for sharing your feedback @bobren110!
As it was mentioned in other thread, it has taken the team longer to identify the root cause of why some users are experiencing rapid battery drain with while syncing the Zip to an iOS device (iOS version 2.41.1). We will continue to investigate, but I don't currently have a timeline for fix. Along with turning off all day sync, we do suggest syncing to a computer or Android device if possible.
If you're having same issues with and Android or PC, please check these tips to troubleshoot battery drain issues.
We really appreciate the time you've taken in order to troubleshoot this! Let me know if you have questions.
Best Answer12-31-2018 06:56
12-31-2018 06:56
Thank you for your assistance!
The issue was a broken band, not the band fittings on the charge 2 device. New straps are in place and secured.
01-03-2019 14:19
01-03-2019 14:19
My Zip has exactly the same problem with battery drain as everyone else. It's insulting to mark this problem as "resolved". I called Fitbit today to ask them to refund my money. At first they offered me a new Zip (why would I want another faulty tracker?) and then they told me that they had to issue the credit to the original buyer (it was a gift from my daughter), not to me. I don't know of any other retailer that does this. Imagine returning a Christmas gift from Macy's and being told they would issue a refund to the person who bought the item!
You've lost a customer, Fitbit!
01-11-2019 12:51 - edited 01-11-2019 12:53
Hi @xenaFB, thanks for getting back. I'm glad to see that you're back on track. Sorry for the time I took to respond.
@martid Sorry for the issues you're having with your Fitbit Zip. We really appreciate your feedback. This has not gone unnoticed and be sure that I will pass this along.
Thanks for your understanding.
Best Answer01-12-2019 07:30
01-12-2019 07:30
I have a new Fitbit zip and the brand new battery lasted 2 days. Tech ‘support’ said it was a known issue and the engineers were working on it and wouldn’t do ANYTHING. Really? This a 4 year old problem. They told me to wait for a solution as a replacement won’t solve the problem.
The last one I had was replaced and it works fine. Gave it to my son and ended up with another lemon. Not recommending Fitbit to anyone.
Best Answer01-12-2019 07:59
01-12-2019 07:59
01-12-2019 08:30
01-12-2019 08:30
Best Answer01-12-2019 09:43
01-12-2019 09:43
