07-31-2017 13:08
07-31-2017 13:08
For at least three of the past six weeks, my Zip's weekly summary of steps has shown several days with 0 steps, even though I have the device in my pocket every day. Total steps for the other days are accurate. Battery does not need changing. Suggestions please. Thanks.
Best Answer07-31-2017 18:45
07-31-2017 18:45
That's what happened to mine. I thought the battery was just dying. Now my Zip is just dead and no longer works. Had it 3 years and 4 months. I'm not sure what to do now, or if I will buy a new one or not.
Best Answer08-01-2017 07:08
08-01-2017 07:08
Thanks for your reply. Did you get any notice that your battery was going, from either an email or an icon on your Zip? I haven't, but perhaps I'll try a new battery and see if that helps.
Best Answer08-06-2017 18:44
08-06-2017 18:44
Same for me. Battery is fine. I deleted my zip from app as suggested. Now the app can find my zip but cannot connect it. Very frustrating. Zip worked perfectly and synced fine up until 2 months ago. Became intermittent but I could manually get it to sync. Now I just have an expensive pedometer that won't sync to any device.
Best Answer08-06-2017 19:33
08-06-2017 19:33
I figured out the issue with my zip was that the metal connector at the base had been pushed in some how and the battery was not connecting. It kept dying, I kept tapping it and it sounded hollow or like something was loose. I took it off and laid it on a table. Later on, it was on and the screen worked, but when I picked it up it went dead again. With the connector pushed in the battery was "loose" inside the unit, sometimes touching the connector, sometimes not. I used a pair of tweezers to pull the connector out a little bit, and it's been perfect ever since. syncs just fine, too.
When it was acting up there was no notification the battery was dying.
