12-19-2016
01:21
15:28
MariamV
12-19-2016
01:21
15:28
MariamV
My zip is not counting my steps. I have updated, cleaned it and reset it twice. It will count a few steps after the reset then stops again.
Moderator edit: format
12-20-2016 07:14
12-20-2016 07:14
Since you have reset it several times it is time to Contact Support
http://help.fitbit.com/?cu=1
Im sure they will help you!
Wendy | CA | Moto G6 Android
12-27-2016 15:35
12-27-2016 15:35
Hey, hey, hey @Pammiesue! Nice to see you around. Adding to @WendyB's post and by what you are describing it made me think that perhaps the side spring may be bent as a result of improper battery insertion or pressure being applied to the back housing. Verify that there is proper contact between the battery and the battery contacts inside your Zip.
You can do this by opening the battery door of your Zip, removing your battery, and ensuring that the silver battery tab located in the lower right half of your tracker is flush with the white box outline in the tracker housing. The process can be followed here. Good luck!
Did you receive the answer you were looking for? Mark the post as an accepted solution! 🙂
12-29-2016 14:58
12-29-2016 14:58
I have changed the battery, cleaned the spring and adjusted the spring in the battery compartment. Nothing changes. Zip shows proper time, no steps no distance, but has a calories burned amount (that does not match the app on my ipad). In fact, the Zip will not sync with the ipad app. It keeps saying I need to tap the Zip to wake it.
12-29-2016 16:45
12-29-2016 16:45
@thejafar thanks for joining us in this thread! I highly appreciate you took the time to troubleshoot this beforehand. Have you checked that your iPad is a compatible device? Click here for the compatible devices list. Also, make sure to follow these steps to troubleshoot any syncing issues your Zip might be experiencing. Good luck!
Keep me posted.
12-29-2016 19:56
12-29-2016 19:56
01-02-2017 12:11
01-02-2017 12:11
@thejafar great news! Have you been able to sync your tracker by now? Also, did you check the steps I posted to troubleshot any syncing issue? Do let me know. I'll be around!
