09-05-2018
10:20
08:57
YojanaFitbit
09-05-2018
10:20
08:57
YojanaFitbit
I have had 3 Fitbit one. I had replacement ones sent, but they were always reconditioned & did not stay working for long. I bought a Zip, thinking that would work better, since it was battery operated. I purchased it in November & since July, it has not tracked properly. It eats batteries & sometimes syncs & sometimes does not. I do not want to wear a device on my wrist, because I am in & out of chemicals & water a lot. the zip has been very disappointing. I am an active person & would love a device I could count on, these have not been it.
Moderator edit: Updated subject for clarity.
09-06-2018 08:56 - edited 09-06-2018 08:58
Hi @sandy07, thanks for sharing the information on your post. Sorry to hear about the issues that you've had with your trackers. I totally understand why you want to keep using a clip Fitbit.
Thanks for all the steps that you've tried with your Zip. What model of phone are you using? I'd like to check the basic things as you're having battery and syncing issues with it, please check the following:
Requirements:
If the syncing issue remains with a mobile device I would recommend following the steps below:
Hope this helps, let me know if you have questions about it.
09-06-2018 10:40
09-06-2018 10:40
09-09-2018 08:22 - edited 09-09-2018 10:50
Thanks for getting back @sandy07 and for confirming the steps that you already try.
I think that it's best if you check with our support team what is the next step. I've already requested a case on your behalf. You should soon receive an email from customer support at the email you used to register with the Community Forums.
Please keep me posted!
