02-05-2019 09:55
02-05-2019 09:55
Since I did the latest software update my zip wont sync unless I take the battery out to reset it
02-05-2019 10:01
02-05-2019 10:01
Exact same issue here and I noticed others with the complaint
02-08-2019 15:41
02-08-2019 15:41
Same problem......does anyone have it resolved yet and can share what to do?
02-08-2019 15:44 - edited 02-08-2019 15:46
I'm not sure what phones you are all having bb problems with, there are reports of sync issues with the latest Android app.
Clearing the Fitbit app cache or data seems to help.
While not ideal if restarting the tracker works this would be an option. I would rather not play to much with the battery for and try steps with the app.
02-11-2019 17:19
02-11-2019 17:19
Be nice if you could simply find the previous, working software version and reinstall that. Don't know how you find that version though
