10-20-2020
01:07
04:20
JuanJoFitbit
10-20-2020
01:07
04:20
JuanJoFitbit
After the latest update with Win10 on 10-14-2020, my Zip will no longer pair with Bluetooth. When I try to connect my Zip, I get the message, "Try to connect your device again." This happens over and over and is so frustrating! I tried to troubleshoot the problem but Bluetooth is fine and I have all the latest drivers. I tried an Uninstall and then Reinstall two times through the MS Store apps. Tried the Google Apps store and same thing ; nothing solves my problem! I have lost all steps for several days now. Battery is full. Zip just stopped working at 11:30 p.m. on 10/14/20 and I can't figure out why. Does Fitbit need to do something to sync with the latest MS updates? I have uninstalled the app and will probably stop using the Fitbit and go for a manual pedometer. No more computer problems that way!
Moderator edit: format
10-22-2020 21:00
10-22-2020 21:00
Worked PERFECTLY! Thanks!
10-22-2020 21:27
10-22-2020 21:27
Thanks so much for your help! I have been so frustrated my Zip would not sync for the past 3 DAYS since my phone updated. Your solution worked perfectly and it finally syncs again! And it somehow kept my steps! THANKS AGAIN!
10-23-2020 07:01
10-23-2020 07:01
After useless advice from official Fitbit help on Twitter and via email (buy a new one was their suggestion) I tried uninstall and reinstall and THAT WORKED! Lost steps from the last few days but at least it’s working! Thank you!!
10-23-2020 08:04
10-23-2020 08:04
Support had me replace my device with the same zip device, everything worked fine, no loss of the steps data!!
10-23-2020
14:50
04:22
JuanJoFitbit
10-23-2020
14:50
04:22
JuanJoFitbit
Two questions, how do you talk to someone? I can't find a phone number; and I can't find out to remove the zip and reinstall. Please help. Thanks.
How do I uninstall and reinstall? I can't figure it out.
Moderator edit: merged reply
Best Answer10-25-2020 12:10
10-25-2020 12:10
I deleted my zip, when I try to set up a new device it shows a picture menu but zip is not on it! GRRRRR.
Best Answer10-25-2020 12:26
10-25-2020 12:26
Best Answer10-27-2020 23:12
10-27-2020 23:12
Mine too! Logged on to Fitbit rather than app and it did sync but now it’s not syncing all . Yesterday played golf and it’s only recorded. 1300 steps .very frustrated !
Best Answer10-29-2020 07:43
10-29-2020 07:43
Thank you- it was making me crazy couldn't fix, was afraid to remove device that it would delete all my data,
But all is good - again thank you!!!!!!!
Best Answer10-29-2020 12:35
10-29-2020 12:35
Best Answer10-29-2020 22:54
10-29-2020 22:54
Mine stopped syncing too. Says no device found. When will FitBit fix this? The devise only hold 10 days of memory. This is obviously an app issue, when will they fix it? Do we have to write FItbit directly?
Best Answer11-02-2020 08:35
11-02-2020 08:35
You hit the "Nail on the Proverbial head" My last sync was 10/19/20 It will NOT sync for anything !! No Bluetooth for it.
11-03-2020 05:32
11-03-2020 05:32
They don’t support the Zip anymore. I can’t stand to wear a watch so when mine dies, don’t know what I will do.
Best Answer11-03-2020 05:33
11-03-2020 05:33
Did you try removing the battery? That’s what fixed mine,
14:30
05:00
JuanJoFitbit
11-05-2020
14:30
05:00
JuanJoFitbit
I'm having the same issue!
Did you have to remove the app from your iPhone to get it to work? Mine says, "No Fitbit device found."
Best Answer11-08-2020 22:15
11-08-2020 22:15
877-623-4997. From 4:00 am to 9:00 pm PT
Best Answer11-10-2020 13:37
11-10-2020 13:37
I did the same thing. Removed the device and reinstalled. That solved the problem. It’s syncing again.
Best Answer11-14-2020 12:29 - edited 11-14-2020 12:30
Hi @SunsetRunner if you are doing this through your phones Bluetooth, you are correct, you should not be able to connect this way, never have - never will
If the tracker is not syncing, try these steps.
