02-03-2019 11:58
02-03-2019 11:58
My zip was syncing fine until my s9 had an update. Now the zip will not pair with my phone. I have tried uninstalling and reinstalling the Fitbit app. I have taken the battery out of the zip. I have attempted to change settings on the app and my phone. My phone's bluetooth and location are on. Still no luck. My phone will find my zip but says it cannot pair and to check device settings. Fitbit keeps popping a message that my zip and my app need linked. Please help.
02-03-2019 12:20
02-03-2019 12:20
Same problem. I feel I've tried everything!!
02-03-2019
13:41
11:10
YojanaFitbit
02-03-2019
13:41
11:10
YojanaFitbit
I can only get it to sync by using the "Fitbit Connect" app on my computer which is not at all convenient.
Same issue, and have tried everything.
Any answers out there?
02-03-2019 13:49
02-03-2019 13:49
I am having the same problem...and have tried everything also.
02-03-2019 15:04
02-03-2019 15:04
I just had my second chat with Fitbit. The answer is "they know there is an issue with the Android System 9 update and they are working on it". If you get a system update indication, make sure you accept it.
02-03-2019 17:22
02-03-2019 17:22
02-03-2019 18:31
02-04-2019 16:38
02-04-2019 17:00
02-04-2019 17:00
Now what? Driving me insane!
02-05-2019 07:07
02-05-2019 07:07
I cannot sync either. Has anyone found out what the problem is?
02-05-2019
10:06
11:26
YojanaFitbit
02-05-2019
10:06
11:26
YojanaFitbit
Same here! I had an update that came through last night, but it didn't help.
02-05-2019 11:24
02-05-2019 11:24
Welcome to the Forums @RaptorK, @christinadade, @JoelyB and @jenn29love. Nice to see you here @Smdavis, @mmaye, @Jnewey and @Geeta71.
Thanks for all the feedback given and for all the steps that you've tried! If you're having syncing issue with your Zip, please confirm that you've tried the following steps on your Android:
Check your phone Permissions and leave location on to keep syncing and getting notifications with your phone, for more info check this suggestions from @ErickFitbit. ![]()
If that doesn't work let's check some requirements that your phone and Zip should have in order to successfully communicate:
Requirements:
If the suggested above is not working, it might be that you're having this syncing issues due to the latest Android version, some users have reported some issues with Android 9.0 (Pie) version. If that's the case, we appreciate your patience and look forward to getting you back on track. In the meantime, I'd suggest to sync your tracker with a different device or a PC, so you don't loose your data and you can keep the time on your Fitbit.
Thanks for checking that information, please keep me posted.
02-05-2019 18:54
02-05-2019 18:54
Having the same problem and have done the same thing. No resolution to date.
02-07-2019 05:28
02-07-2019 05:28
I've tried this and it doesn't work. The sync stopped on Sunday, 2/3/19 AFTER our phones did the Samsung OS update. All of our phones are up to date except this app which still won't sync.
Please advise.
02-07-2019 05:47
02-07-2019 05:47
I've done it also n it's not working either
02-07-2019
19:44
09:06
YojanaFitbit
02-07-2019
19:44
09:06
YojanaFitbit
I've done everything recommended and I can't get it to work. I'm very disappointed in Fitbit.
Moderator edit: Word choice.
02-07-2019 21:38
02-07-2019 21:38
Same exact problem!! Have tried EVERYTHING multiple times, in various orders! So frustrating!!
02-08-2019
08:51
09:07
YojanaFitbit
02-08-2019
08:51
09:07
YojanaFitbit
Doing an Apps reset seemed to solve the problem
for the moment but will have to use it for a while
before can say a reset does the job
Moderator edit: Removed personal information.
02-08-2019 09:18
02-08-2019 09:18
Hi @Geeta71, thanks for getting back to the Forums for trying the steps! Can you tell me what exactly did you try? What model device are you using? Have you tried with a computer or other platform?
@MelMinn, @beni23, @Katarg Welcome to the Forums! Thanks for trying these steps. Do you have the option to try a different platform?
Thanks for the update @frib! I'm glad to see that this is working for you. Please keep us posted.
I'll be around.
Best Answer02-08-2019 09:49
02-08-2019 09:49
