02-03-2019 11:58
02-03-2019 11:58
My zip was syncing fine until my s9 had an update. Now the zip will not pair with my phone. I have tried uninstalling and reinstalling the Fitbit app. I have taken the battery out of the zip. I have attempted to change settings on the app and my phone. My phone's bluetooth and location are on. Still no luck. My phone will find my zip but says it cannot pair and to check device settings. Fitbit keeps popping a message that my zip and my app need linked. Please help.
02-11-2019 06:59
02-11-2019 06:59
Sadly this still doesn't work with my fitbit zip. I have the latest version, managed to check that. Took the battery out etc all synced great, hadn't lost any data. However about an hour later thought i would try it again and turned on bluetooth on phone again: I don't leave it on all the time . Bluetooth on phone finds the zip but tells me it 'couldn't pair. Check settings for this device and try again.' With the actual app on phone (Samsung Galaxy s9) it says, after hanging for ages 'can't find tracker'.
Not sure what I do now. How do you check the settings for the device...is that the zip or the phone?Is it me? The new instructions did sound just like we have been doing ie removing battery, turning bluetooth on and off etc.
02-11-2019 07:03
02-11-2019 07:03
02-11-2019 07:30
02-11-2019 07:30
Phew glad it is not only me.
02-11-2019 08:24
02-11-2019 08:24
02-11-2019 08:54
02-11-2019 08:54
02-11-2019 13:14 - edited 02-11-2019 13:17
Hi guys thanks for getting back. Sorry for the time it took me to respond.
Thanks a million for the help you provided on the thread @frib, we're aware that in some cases those steps only work once but we've already escalated this issue.
That's a excellent workaround @rnmh1964, thanks for sharing it with us. @MelMinn thanks for sharing those steps, I'm sure some of the users will give it a try.
I appreciate all the effort and time that you've put into this, in order to help your Zip to connect with your mobile @Katarg, @JoelyB, @capdan, @Geeta71, @rnmh1964, @aelucas and @jenn29love.
Our chat team handles the same information that we do, thanks @Jnewey and we're still waiting for any other detail about it.
Thanks for reporting this @auntdebbie and @Chrisp1213. As we've mentioned before if you already tried all the suggested steps and it is not working, it might be that you're having this syncing issues due to the latest Android version, some users have reported some issues with Android 9.0 (Pie) version. If that's the case, we appreciate your patience and look forward to getting you back on track. In the meantime, I'd suggest to sync your tracker with a different device or a PC, so you don't loose your data and you can keep the time on your Fitbit.
We'll let you know any update, as soon as we get more details.
02-11-2019 13:25
02-11-2019 13:25
02-11-2019 14:10
02-11-2019 14:10
02-11-2019 18:28
02-11-2019 18:28
02-11-2019 19:07
02-11-2019 19:07
02-12-2019 09:34
02-12-2019 09:34
All the fixes that have been tried don't work. This needs a software solution.
What is so disturbing to me is that when you submit a problem you get no identifier case # to track so you are always starting from the beginning each time you report this issue. I don't think they are serious in solving it. Probably want Samsung to solve it instead of working with Samsung to get the issue solved.
We are at the mercy of the industries egos.
02-12-2019 18:48 - last edited on 02-13-2019 09:44 by YojanaFitbit
It worked! Thank you so much for the tip!
Ok. So the same thing happened to me... and so many others. Someone posted the following and it worked for me. But you have to do it in this exact order:
- make sure you have the most recent Fitbit app which is 2.87 (20213363)
- turn off blue tooth.
-restart phone
- while phone is restarting, restart Fitbit (take out battery for at least 15 seconds, then place it back).
- turn blue tooth on
I should mention I had uninstalled Fitbit (zip) so it was as if I had just bought the device. Yes, I lost ALL my steps for 5 days. Ugh! But it worked!!!
- then sync!
This is posted in yesterday's comments under
MelMinn- this is the person who posted the instructions. What a relief!
02-12-2019 19:32
02-12-2019 19:32
02-13-2019 08:37
02-13-2019 08:37
02-13-2019 09:55
02-13-2019 09:55
Thanks for trying those steps @beni23 and @Smdavis! I hope this works for your in a longer term. We've received feedback from a lot of users. @aelucas, @frib Thanks for keep adding your comments to help others.
@MelMinn and @Katarg We appreciate your time, as our team mentioned we've escalated this and we're waiting for any update to fix this. Thanks for sharing this information.
I'll be around.
02-13-2019 10:52 - last edited on 02-15-2019 11:48 by YojanaFitbit
Hi,I know the development team is working on a resolution, however I was wondering if there are any real updates? Where are they in the troubleshooting process? Have they identified the cause? Have they developed a solution? Has the solution gone through UAT? Is there any real information that can be shared?Warmest regards,Alicia L.
Moderator edit: Removed personal information.
02-13-2019 10:54
02-13-2019 10:54
Same problem and I even reset my phone but still the same issue
02-13-2019 16:45
02-13-2019 16:45
Ugh!! I'm having the same problem!
02-14-2019 18:33
02-14-2019 18:33
Has there been any fix to this yet?
02-14-2019 18:35
02-14-2019 18:35
Not that I'm aware of. I paired with a different device for now.
