02-03-2019 11:58
02-03-2019 11:58
My zip was syncing fine until my s9 had an update. Now the zip will not pair with my phone. I have tried uninstalling and reinstalling the Fitbit app. I have taken the battery out of the zip. I have attempted to change settings on the app and my phone. My phone's bluetooth and location are on. Still no luck. My phone will find my zip but says it cannot pair and to check device settings. Fitbit keeps popping a message that my zip and my app need linked. Please help.
02-14-2019 18:44
02-14-2019 18:44
02-15-2019 07:25
02-15-2019 07:25
I'm having the same issue.
02-15-2019 11:56
02-15-2019 11:56
Hi @aelucas nice to see you on the Forums again, at this moment we don't have more information about this. We'll let you know as soon as we get more details.
Welcome aboard @Shea1, @Nicole0513, @Littleoldgeek and @wendycollie, thanks for reporting this. Have you checked my previous response here? Sorry for any inconvenience, I hope we can have updates about this soon.
I'll be around in case that you have questions about it.
Best Answer02-16-2019 10:30
02-16-2019 10:30
I have the same issue. I restart the Zip and it will sync one time and that's it. Is there a fix for this coming soon? So frustrated....
02-19-2019 07:58
02-19-2019 07:58
Welcome to the Community Forums @JakesGirl!
Thanks for trying those steps. Please confirm that you've tried the steps suggested here. If you noticed that you've having exactly the same issues described there then I'd suggest to sync your tracker with a different device or a PC. As mentioned above we've escalated this, we'll keep you updated as soon as we have any other detail.
See you around.
Best Answer02-21-2019 17:49
02-21-2019 17:49
02-22-2019 09:31
02-22-2019 09:31
I am experiencing the same problem since my update!!
02-22-2019 15:51
02-22-2019 15:51
02-22-2019 16:22
02-22-2019 16:22
Samsung S9 updated to ver.9.0. The Fitbit app no longer able to pair (sync). I have tried everything from remove and reinstall the app, remove and reinstall battery, remove and reinstall device with no avail. No problem sync to the laptop.
02-22-2019 16:42
02-22-2019 16:42
Several weeks later and still no solution. I've also talked with Samsung who stated they are aware of the issue and are working to fix it. I asked for a timeline, but they could not say for sure. This is frustrating.
02-22-2019 17:54
02-22-2019 21:47
02-22-2019 21:47
My Samsung S9+ updated to Pie a couple of days ago and Fibit app and my Zip tracker are also having sync issues ever since. Uninstalled and reinstalled the app twice, taken battery out of Zip, restarted my phone, no luck. It's just not working accurately. What is going on?
02-23-2019
04:16
12:43
YojanaFitbit
02-23-2019
04:16
12:43
YojanaFitbit
It is SO frustrating! This is one of the reasons I do not like doing phone updates! Hoping someone has a solution.
Thank you for all of the information. It seems like A LOT of steps to go through. I am hoping the fix due to the S9 update happens soon.
02-25-2019 04:23
02-25-2019 04:23
02-25-2019 07:52
02-25-2019 07:52
02-25-2019 10:14
02-25-2019 10:14
Don't know who is going to fix this problem, looks like finger pointing.
02-25-2019 11:12
02-25-2019 11:12
02-25-2019 14:00
02-25-2019 14:00
02-25-2019 14:04
02-25-2019 14:04
02-25-2019 17:42
02-25-2019 17:42
