04-30-2023
07:36
11:19
04-30-2023
07:36
11:19
How do I connect my fitbit zip to my phone? Please any help.... this is driving me crazy
Best Answer04-30-2023 08:41
04-30-2023 08:41
Hi @Georgie-Rae see if anything in this article helps - click to read. Things have changed along the way and you must use a compatible mobile device or tablet to set up and sync your Zip. We can't use the computer anymore.
Best Answer05-04-2023 00:32
05-04-2023 00:32
Hi @Odyssey13, I found a way but now having problems connecting to my zip hoping that article helps with this situation now
Best Answer05-10-2023 06:37
05-10-2023 06:37
@Georgie-Raehow's it going? You said you had found a way and now I'm curious. As long as your smartphone is compatible, you should be able to connect, but don't forget that often restarting the Zip by removing the battery can help.
