07-24-2016 16:33
07-24-2016 16:33
I've had my Zip for over two years (currently at 13 million steps) with almost no problem. I sync with a desktop computer (yes, I'm over 50), and just noticed that it hasn't synced in the last couple days. I ran the update (it says I'm now at 1.0.3.5512. which is up to date), but I still can't sync.....it says I don't have an internet connection. Obviously, I do.
It talks about uninstall/reinstall, but I'm hesitant because I don't want to lose my history.
I'm old school - it clips on my belt, and it syncs with a desktop - I haven't messed with connecting it with a phone, and probably won't until there's no other choice. Everything has worked great until this week. It's still counting my steps on the device....just not syncing with the software. Any advice? Thanks.
08-30-2018 16:33
08-30-2018 16:33
08-30-2018
16:50
14:00
YojanaFitbit
08-30-2018
16:50
14:00
YojanaFitbit
Continuous sync. It worked fine the first 3 weeks, then it stopped working.
I switched it from being paired to my personal phone to my work phone (both
are Pixel 2's) and same result.
Rebooting the Zip resolves it, cycling Bluetooth on the phone does not.
Blaming the phone is the easy answer...
Matthew S
Moderator edit: Removed personal information.
08-30-2018 17:09
08-30-2018 17:09
You could try Grandkiddos idea and try a new battery, although if you had a weak battery the Zip should give you the low battery warning. If it makes you feel any better every issue I have had with my Zip the past 5 years is from either Android updates or Fitbit updates which somehow messed with the bluetooth settings. Through all of these issues I was always able to still sync to my desktop computer using the dongle!😁
09-02-2018 09:01 - edited 09-02-2018 09:03
Hi @apraetor, it's nice to have here, welcome! Thanks a million @Grandkiddos and @JayLatko for the help. ![]()
Thanks for all the steps that you've tried. If those recommendations don't work let's check some requirements that your phone and Zip should have in order to successfully communicate:
Requirements:
If the syncing issue remains with a mobile device I would recommend following the steps below:
Hope this helps and welcome again!
09-02-2018 15:09
09-02-2018 15:09
@YojanaFitbit Sorry, no dice there. As mentioned, the phone is a Google Pixel, and the issue also occurs on a spare Pixel 2 in factory-reset state used for review purposes.
The rest of that is generic stuff I ran through long before spending time reaching out. Thanks though.
Best Answer09-04-2018 13:00
09-04-2018 13:00
I purchased a Zip from Amazon in June. Worked great for a few weeks and then died. Because I'd purchased a warranty Fitbit replaced it. New one worked fine for a week or so and then stopped syncing. Called customer service and explained we had uninstalled, reinstalled, restarted the phone and anything we could think of using the online helps. Still wouldn't sync even when we pushed the "sync" button. Today I called customer service again and they had me do the same things, check blue tooth, check settings, restart my phone and remove my battery. It synced. Great. 3 hours later, hasn't synced since. 😞
Best Answer09-04-2018 13:11
09-04-2018 13:11
09-04-2018 13:26
09-04-2018 13:26
I thought I had to leave the dongle in the computer the whole time anyway? So yes, it's there. 🙂
09-04-2018 13:35
09-04-2018 13:35
09-04-2018 13:47
09-04-2018 13:47
09-04-2018 14:11 - edited 09-04-2018 14:23
Thanks for getting back @apraetor. Your comments are greatly appreciated @JayLatko.
Since those steps didn't solve the issue you're having with your Fitbit Surge @apraetor, I've requested to our support team to create a case on your behalf. You should soon receive an email from customer support at the email you used to register with the Community Forums.
@TexasTerri Thanks for trying those steps, did you respond to support? I think that you need to get back to them to let them know the resolution of the troubleshooting steps, so they can give you the next step.
Please keep me posted! ![]()
09-04-2018
14:44
07:38
YojanaFitbit
09-04-2018
14:44
07:38
YojanaFitbit
I do have it loaded on the computer with the dongle attached. Sitting at my computer with the phone and fitbit Zip I click on the sync button and it spins for a (long) bit and then goes to a red exclamation mark. ?? So it doesn't sync automatically through blue tooth to phone or dongle to computer.
@YojanaFitbit When I disconnected with Customer Service this morning it had synced while I was on the chat. So I ended the chat. But my Sync screen says last update was today at 11:14 (when I finished the customer support chat). Although I have been next to my computer all day and even hit the "sync" button several times when I noticed my Zip step count didn't match my app count or dashboard number on the computer. It spins for a little while and then shows a red exclamation mark. It won't sync.
15:07
07:36
YojanaFitbit
09-04-2018
15:07
07:36
YojanaFitbit
Thanks for the suggestion. I did try a new battery initially, just to
eliminate things. The Zip is definitely working other than sync -- once I
pull the battery out to force the Zip to reboot it starts syncing and dumps
the past several days of history (I force reboot it every 4-5 days right
now). I even went as far as pulling my old Pixel out of the closet (since
the Pixel 2 is not officially supported) and it has the same problem.. as
does my work phone (iPhone 7). Syncs fine for a few hours, then nada.
Matthew S
09-04-2018 15:27
09-04-2018 15:27
Yup. That's the exact same issue I have. I do have a Pixel 1. My old Fitbit One worked for years and never had a problem with it. It was just going to the Zip where I lost the sync all together.
09-05-2018 07:55
09-05-2018 07:55
Thanks for confirming all those details @TexasTerri and @apraetor. Since you already try all those steps and your Zip keeps acting erratically it's best to check the next step with support. I've contacted them directly to check your case, you will get some information from them shortly. Please reply with the information that they need.
Let me know if you have questions about it.
09-05-2018 14:40
09-05-2018 14:40
@YojanaFitbit Thanks, I'll keep a look out for the email, nothing so far.
09-06-2018 11:35
09-06-2018 11:35
Hi @apraetor, thanks for reaching out. I've checked the information with our team, sorry for the time this is taking. You'll receive the information soon.
Thanks for your understanding.
04-17-2019 08:26
04-17-2019 08:26
yeah, i've been removing/installing my battery each evening for months now- come on!! really?!?
Best Answer09-02-2019 10:09
09-02-2019 10:09
I have uninstalled and reinstalled my Fitbit app. I have taken the battery out of my Fitbit Zip fir 30 minutes and still it wont sync. In MIGHT pair, and that might last 15 minutes but it doesn't get me through the day. I've been going through this for MONTHS and I'm getting extremely frustrated (PISSED OFF) at both Fitbit and customer service!!
Best Answer09-02-2019 10:15
09-02-2019 10:15
