03-13-2017 05:42
03-13-2017 05:42
My fitbit is syncing only at 2:57 PM since Friday. It used to sync throughout the day and keep track of a 24 hour period. I didn't change anything. Any advice on how to fix this?
03-14-2017 17:53
03-14-2017 17:53
Thanks for stopping by @CaB05! This sounds odd. If you haven't tried, I'd like to suggest you to restart your tracker. Also, please log out from the app and reboot your phone. Once your phone is up please log back in.
Keep me posted with the outcome! 😉
03-16-2017 19:02
03-16-2017 19:02
03-21-2017 19:13
03-21-2017 19:13
Thanks so much LucyFitbit. I logged out of the app and restarted my phone and it finally synced.
03-22-2017 16:56
03-22-2017 16:56
if i restart my tracker, won't i lose my steps? i have restarted/reinstalled the app on both my phone and laptop and it still won't sync....the last one was earlier this afternoon....i have tried all the suggestions listed except for restarting the actual zip. help!!!!
03-24-2017 11:35
03-24-2017 11:35
I'm having the same problem, my fitbit is on an all day sync, but will only sync until 2 pm. I average between 12000 and 22000 steps so im losing about half. Ive tried taking the battery out and restarting, ive tried uninstalling the fitbit app and reinstalling. I've tried turning the all day sync off, but then it wont sync at all, so im losing all my steps. Any more hints that might help?
Best Answer03-25-2017 00:04 - edited 03-25-2017 00:05
I had the same trouble. I did everything LucyFitBit said to do and it worked. I read the latest posts, but I don't see that any of you actually logged out of the fitbit app. So everybody try taking out the battery of the fitbit and then putting it back in. Now go into the app and actually click logout. Do not just close the app. Now restart your phone. When you restart, be sure your bluetooth is back on and then log back into the fitbit app and try syncing again. It worked for me. Hopefully it works for all of you as well.
03-25-2017 21:02
03-25-2017 21:02
Best Answer03-28-2017 12:35
03-28-2017 12:35
Sorry. I was really hoping it would work for you.
Best Answer04-05-2017 16:50
04-05-2017 16:50
Hey everyone -- I recommend checking out the troubleshooting suggestions here. Hope this helps!
04-06-2017 19:50
04-06-2017 19:50
Trouble shooting proved that the bluetooth in the fitbit has failed. A friend added it on his fitbit app on his Android and the same thing happened. It would not sync. His fitbit would on both of our devices. It is out of warranty. I am shopping for a new device. Thanks.
Best Answer04-08-2017 20:22
04-08-2017 20:22
Zip doesn't work doesn't give any data
Best Answer04-08-2017 20:24
04-08-2017 20:24
@CaB05 wrote:My fitbit is syncing only at 2:57 PM since Friday. It used to sync throughout the day and keep track of a 24 hour period. I didn't change anything. Any advice on how to fix this?
Best Answer04-08-2017 21:10
04-08-2017 21:10
I had tried those things and they did not work . The blue tooth in the tracker no longer works. I tried adding a friends fitbit and it did register on my phone app. Mine does not work but lights up as it measures steps but will not sync. Therefore we know it is my trackers blue tooth. Thanks
