12-26-2016 18:14
12-26-2016 18:14
It would be helpful if the belt clip be closed and belt slide through it so it can not slide off accidently
12-27-2016 15:58
12-27-2016 15:58
@craizychemist Thanks for joining the Fitbit family! The belt clip of the Fitbit Zip should not accidentally slide off. It should clip securely on your shirt pocket, bra, pants pocket, belt, or waistband.
Do you still have the silicone holder? Is the clip broken?
If you have any suggestions about the Zip's belt clip you can go to the Feature Suggestions Board. That way, other users can vote for your idea!
Keep me posted!
12-27-2016 19:26
12-27-2016 19:26
12-28-2016 05:23
12-28-2016 05:23
@craizychemist Thanks for your reply! How are you wearing your Zip? I recommend wearing it in a different place than the one you were using when it slipped off. The pants pocket is a great place to wear it and you don't need to clip it there.
When I had my Zip I tried using it inside my pocket and it worked fine! You could try that to check if that works for you.
Keep me posted!
