02-10-2016 09:06
02-10-2016 09:06
I have never had a problem with using fitbit connect and syncing my Zip. I replaced the battery in the zip last week. I plug dongle in to usb port. open fitbit connect. ask it to sync and it tells me to plug in dongle!!!
I have uninstalled fitbit connect and reinstalled but I get the same message. I have unistalled fitbit connect and tried syncing without dongle..nothing is working. Help!!
Considering the fortune this company must be making on a piece of plastic with a chip in it you would think the apps would be more reliable or at least helpful advice given. I have yet to find any easy answers.
02-10-2016 09:23
02-10-2016 09:23
Also, which OS are you running? If you're running Windows 10 you may sync with the Fitbit App using just bluetooth 4.0.
Frank | Washington, USA
Fitbit One, Ionic, Charge 2, Alta HR, Blaze, Surge, Flex, Flex 2, Zip, Ultra, Flyer, Aria, Aria 2 - Windows 10, Windows Phone
Best Answer02-10-2016 09:13
02-10-2016 09:13
Hello @Lola_marigold,
Welcome to the community!
I would try a different USB port and/or rebooting the computer. While it may be a bad dongle, I've seen reports of different USB ports being temperamental for some devices. I myself have experienced this with a USB drive on an older laptop.
Let me know if this works.
Best Answer02-10-2016 09:22
02-10-2016 09:22
TY for your quick reply. I did try a different port. I will try rebooting now.
Best Answer02-10-2016 09:23
02-10-2016 09:23
Best Answer02-10-2016 12:28
02-10-2016 12:28
Seems it is working now although the first few times I tried syncing it kept telling me there was an error. all is good though. Thanks 🙂
Best Answer08-22-2017 09:38
08-22-2017 09:38
Hi,
I've just about given up and going to bin the Fitbit - I've struggled for 2 or 3 hours now and it is useless.
Got a new FB charge2 given to me by the company. I have a company Blackberry Z10 - so that's not supported. Also got a windows 7 Enterprise laptop from the company and I just can't get around this Dongle message.
If there is a solution I'll try for 10 more minutes then it's goodbye fitbit - as another useless piece of technology someone is making a fortune on. I wonder how many are sold and sit in drawers or bins as they cannot be made to work?
Best Answer08-30-2017 11:18
08-30-2017 11:18
I'm a little confused why you're posting about a Charge 2 on the Zip forum, but okay...
I believe that if you get in touch with support and tell them that you're still running Windows 7, then they'll send you a USB dongle free of charge.
Fitbit chose not to include it in the box for the Charge 2 since most folks have smartphones or are running a current OS on their computers. Windows 7 was released on 2009. To put it in perspective, this is when the iPhone 3GS was released.
I hope this helps.
Best Answer08-31-2017 01:49
08-31-2017 01:49
Best Answer08-31-2017 16:26
08-31-2017 16:26
Ahh... The Zip is a tracker model, like your Charge 2 is a tracker model. Fitbit has over 10 different tracker models.
You can still legitimately contact support and ask for a dongle (especially since you bought one). It may be nice to have for a 2nd (home?) computer.
You can say that your tech equipment is aged, but if it still works why fix it? Well, because there are new features (like the Fitbit App) that are targeting the latest platform. This very conversation is a viable counterpoint to 'it still works'. ![]()
Congrats on getting it configured and working. I started my journey with Fitbit over five years ago.
