06-28-2019 21:07
06-28-2019 21:07
Can't synchronize - must have deleted/removed/moved icon of Zip off home screen; can't tap it to begin synchronization. How do I get icon back?
06-28-2019 22:46
06-28-2019 22:46
Hello and welcome to the forums @eawaters
How are you syncing - computer or mobile device? Android, iOS or Windows? The more we know, the better to help you.
06-29-2019 07:04
06-29-2019 07:04
Thanks for reply - I am syncing with older LG phone. Have done so for last 1 1/2 yrs since began using Fitbit Zip with no issue. When I opened app last night there was message box - there often is with message 'good job you hit your goal' or 'Overachiever! you've exceeded your goal'. There is often a 'view' button which will take me to page showing total steps for the day (my goal 10,000) - I clicked before reading closely this time as I usually do and app had switched from tracking Steps to tracking Calories. I am unable to find fitbit icon to sync and cannot switch fro Calories back to Steps ......Limited intellect/technical knowledge shining brightly today!
06-29-2019 20:26
06-29-2019 20:26
@eawaters I've had that happen before on my Android phone with other apps. Try reading the article - click - on trouble syncing. Be sure you have the app on the phone and everything is set. Restarting the device helps, too. Remove the battery for at least ten seconds and let us know how things go for you.
06-30-2019 19:36
06-30-2019 19:36
I had thought to turn phone off then back on prior to posting my first question. Tried taking battery out of phone after reading your reply - didn't seem to make any difference. My app pulls up on my phone just fine- but only with calorie tracker and I'm unable to figure out how to change back to steps tracker. Have had app on my phone for last 15-16 months and never had problem previously. Thanks for suggestions
07-21-2019 11:12
07-21-2019 11:12
Hello @eawaters is your Zip showing as connected to your account.
