showing calories not burned
ANSWERED
I just purchased my fitbit zip I did 22 steps while putting it in the clip and burned 893 calories. on app shows 2 weeks of calories burned. will not reset by removing battery. How in the world do I fix this? Do I need to return it?
1 BEST ANSWER
Accepted Solutions
Hello and welcome to the forums @myjays
When you first get your Fitbit, you will see burned calories. The devices begin the day at midnight, so no matter what time you set up, those burned calories will be there. This article on burned calories may help you. click to read
There is no way for us to remove them, but it won't hurt your step statistics.
Stepping in the U.S.A. since September 2013. Android 14
2 REPLIES 2
Hi there @myjays, I like to see new faces around. Indeed, as @Odyssey13 mentioned before, these calories play an important role on your daily activity. As the article mentioned, your BMR counts almost half of your total calories and start counting after midnight. So is normal to see calories burned at first time in the morning.
As an additional note, when you are in doubt of how many calories you should burn for an exercise, you can use these Calories Calculator for more information.
See you around and let us know if you have more questions.
Roberto | Community Moderator
