04-04-2016
06:56
09:39
04-04-2016
06:56
09:39
Hi there @SunsetRunner its great to see new members around the forums! So it seems that your Zip is not resetting itself at midnight, even after you tried to restart it by taking out the battery for 10 seconds and put it back, right? If so, let me suggest you to please make sure you have the correct timezone setting on your Fitbit account.
Let me know if that works!
05:42
09:39
04-05-2016
05:42
09:39
Thanks for getting back to me @SunsetRunner! Oh! so, your Zip is working fine again right? the data is again resetting at midnight as it should.
Sounds awesome. If this happens again, you can try the suggestion I posted earlier or if you have other questions, you can contact our Support team!
Have a great day!
