08-12-2017 08:32 - last edited on 08-23-2017 14:42 by KateFitbit
My fitbit zip has stopped tracking my steps, have tried re-synching but it won't do it as my e mail is already registered, can anyone help please.
Moderator edit: title for clarity
08-18-2017 19:13
08-18-2017 19:13
Thanks for stopping by @jacwid! This sounds odd. To make sure that your tracker is working correctly, restart it.
Also, Log out from the Fitbit app and reboot your phone. Once your phone is up, log back in. Make sure that you are using to log the email you used to register with the Community forums.
Keep me posted! 🙂
08-19-2017 00:52
08-19-2017 00:52
08-19-2017 12:06
08-19-2017 12:06
Thanks for the reply @jacwid! I appreciate that you have posted that you were able to solve the issue you were experiencing. I'd like to suggest you to post the steps you performed to solve this issue, this can be helpful for other users experiencing the issue you experienced.
Also, I'd like to encourage you to join us at Discussions board, there you can be inspired, find some tips to get moving, eat well, manage weight, sleep better, live mindfully and more!
Give it a look! 😉
08-20-2017 12:21
08-20-2017 12:21
