07-05-2017
19:01
05:31
MarcoGFitbit
07-05-2017
19:01
05:31
MarcoGFitbit
Bafttery life no longer shows on Fitbit face when I press the button
Hello @JannieB, thanks for joining the Fitbit Community, it's great to have you on board! ![]()
Which tracker are you currently using? If you're using a Charge 2, please make sure to update the app as we have released a new version recently and then go to Account > Charge 2 > Menu Items and make sure the checkbox next to Battery is enabled. Make sure to sync your tracker after any changes have been made. Also, please remember that Battery is the last item on the menu and you need to press the button several times for it to show.
I hope this can be helpful, give it a try and keep me posted in case you need anything else. ![]()
