07-23-2016
08:40
04:45
AlejandraFitbit
07-23-2016
08:40
04:45
AlejandraFitbit
Since 2.25 was loaded, my Flex (v81) battery life is barely 1 day, it used to be 6-7. No all day sync and only steps alarm. Had considerable battery use even while sleeping. Have reset the Flex numerous times. Anyone with similar symptoms?
Best Answer07-25-2016 04:50
07-25-2016 04:50
It's great to see you around @Rod77. Thanks for troubleshooting this inconvenience by yourself. Your Fitbit Flex battery can last up to 5 days. Because battery life is affected by use and other settings, actual results may vary. These tips might help when you want to prioritize battery life:
If you keep seeing that your battery is not lasting the time it should, feel free to contact our support team, I know they will be more than glad to help.
Let me know how it goes. ![]()
Best Answer07-25-2016 05:10
07-25-2016 05:10
Best Answer07-25-2016 06:36
07-25-2016 06:36
Thanks for the information @Rod77. I think that it is time for you to contact our support team, I know they will be more than glad to help you out. For a faster response you can contact them via phone or chat.
