12-20-2016 06:12
12-20-2016 06:12
My blaze won't sync fully. It starts the process but then as the bar gets halfway across it starts over again. It is supposed to sync automatically but I've given up on that ever happening as the last two Fitbit devices that I've had never sync automatically. I have Iphone 7plus with latest update.
I don't always go to the app every day but in order for it to sync before it stopped syncing I would have to go to the app. It hasn't synced in a week.
My battery dies faster than ever... have to charge almost every day just to keep it from dying. It died last night after being fully charged the day before... Now my time is off by 2 hours and I can't sync so It won't correct the time.
So my issues:
1) won't sync
2) starts sync then stops halfway through
3) repeat that cycle
4) battery life changed over the past two weeks to almost 1 day batter life.
Best Answer12-20-2016 07:14
12-20-2016 07:14
Mine is doing the exact same thing. I am getting pretty aggravated with it. I have an iPhone 6 and I also am part of the Apple IOS Beta program so my IOS is different from everyone else's but I can see that others are having the same issues with the Blaze continuously trying to sync, not syncing fully, battery draining in a day, and I can't even get the Blaze to pair now.
Best Answer12-20-2016 07:15
12-20-2016 07:15
I have at least gotten it to sync. However, I had to forget this device and lose all my data from the past 7 days. I deleted the device off the iOS app. I tried to re-add it and it couldn't find it. After several attempts at that force shutting down my app and restarting the Fitbit, I went to my bluetooth settings and told it to forget this device.
Once I did that I tried to re-add the tracker it was able to find it after 10 minutes of the spinning circle. I have my data from today but all my data from the previous 7 days are gone. oh well.
hope it will sync automatically as it never does even though I have it set for "All-Day Sync." I had this issue on my old Charge HR as well, that was never able to be fixed.
Hopefully the battery life will be better.
Best Answer12-20-2016 07:40
12-20-2016 07:40
I've done the bluetooth reboot, "forget this device", tried to repair, deleted the device from my fitbit app, force-quit the fitbit app, and rebooted my phone with no results. I have now deleted the fitbit app and I am re-installing it on my phone and will try that. if that doesn't work I am going to look for a new tracker and forget this one. Too many issue with this thing and it appears this has been an ongoing issue fro 2015 with no real fix to the problem.
Best Answer12-20-2016 08:14
12-20-2016 08:14
I would wait until they do some more fixes. Apparently, I missed this in the forum, they are aware of an issue with syncing since the new iOS update and are working on fixes that should help.
I'd wait to get rid of the tracker and buying a new one until they've made their fixes.
Best Answer12-20-2016 10:23
12-20-2016 10:23
I'm having the same issues. I've tried every workaround in the book with no results.
It wouldn't be so terrible if you didn't have to sync to get the time to show up correctly. Now my blaze wont even pair, so there's no chance of that happening. Too bad buyers remorse has struck 4 months after purchase& past my refund date...
Best Answer12-20-2016 11:51
12-20-2016 11:51
Same problem here. Blaze won't sync, time is off and the app freezes on the screen where you put in the four digit code to connect Blaze to phone. This sucks!!!
Best Answer12-20-2016 15:43
12-20-2016 15:43
Having same issues with Blaze, I've removed app and reinstalled. Check Bluetooth, etc. frustrating because it's synced in with Omada to track activity and I've lost 10 days. Looks like last sync was December 10, erg
Best Answer12-20-2016 16:00
12-20-2016 16:00
I'm having the same issue! So frustrating!!
01-09-2017 20:55
01-09-2017 20:55
Grrrr! Literally exact same thing! Dies in less than a day, time is 6 hours off because it fully died and now I have lost a week of data already.
