12-02-2019 14:52 - edited 12-02-2019 18:25
I’m facing this issue where I cannot key in decimal places when entering body fat percentage, in the Fitbit app for iPhone. For example, I want to enter 14.6%, but can only type 14%. I’m using iPhone X running iOS 13.2.3. Anybody has a solution to this? Thanks!
02-05-2020 05:30
02-05-2020 05:30
Update 3.14 makes it work again!
12-04-2019 13:38
12-04-2019 13:38
Hi @AndyWong343, welcome to the Community Forums! Sorry for the delayed reply.
Thanks for bringing this to my attention and for the details that were shared in your post. I'd like to let you know that we are aware of this issue that's affecting the decimal point function and working to resolve it as soon as possible. In the meantime we work on this, my best advice will be to log weight on the fitbit.com dashboard instead.
Your understanding is appreciated, let me know if you have any additional questions.
12-08-2019 21:28
12-08-2019 21:28
Happened to me too after the app update to version 3.11.1. iPhone 11 with the latest version of IOS (13.2.3). My iPhone localization is Finnish with desimal places separator comma (,).
12-10-2019 01:35
12-10-2019 01:35
My Ionic has been failing to allow me to enter the decimal place for about a week now. Up until then it’s been fine.
12-10-2019 08:43
12-10-2019 08:43
I have the same issue.
FITBIT....we are waiting..................
12-10-2019 09:00 - last edited on 12-11-2019 18:32 by RicardoFitbit
I too am experiencing this exact problem. I’m glad to know that it’s not a problem with my phone at the very least. I use this function every day and hope a fix is created soon. Thanks
Moderator edit: Format
12-11-2019 14:41
12-11-2019 14:41
It’s solved now! With the latest update of the Fitbit app for iPhone and latest firmware for my Versa.
12-11-2019 18:35
12-11-2019 18:35
Hello guys, it's a pleasure to continue assisting. Sorry for the delay in responding.
I'm sorry to know that you are experiencing the same issue with the decimal point on the Fitbit app when logging body fat percentage. Please check any Fitbit app updates and let me know if the issue persist.
I'll be around.
12-12-2019 00:55
12-12-2019 00:55
12-12-2019 01:04
12-12-2019 01:04
Oh yes. It was working fine yesterday, but it isn't working anymore today. Why is it like this?
12-12-2019 01:13
12-12-2019 01:13
12-12-2019 07:27
12-12-2019 07:27
I just updated my phone again and updated the Fitbit app. Still cannot enter the decimal point for updating my body fat %
12-12-2019 09:30
12-12-2019 09:30
12-12-2019 14:37 - edited 12-12-2019 14:38
Yes that works. But it still doesn’t solve the problem that you can’t do it in the phone app.
12-13-2019 00:36
12-13-2019 00:36
Not working for me either - thought it was me.
12-14-2019 03:57
12-14-2019 03:57
Hi, I have an Alta HR, app updated to latest version on iOS and still no fat decimals unfortunately.
12-15-2019 01:19 - edited 02-05-2020 05:27
Same probleem here with the iOS app.
For me it started when I downloaded the latest update this week, was fine before that. I think I didn’t download the previous update
Charge 3SE with latest firmware (Netherlands), IPhone SE 13.3 firmware.
i know I can use the Webbrowser dashboard, but not the ease of use I’m looking for of course.
edit: update 3.12.1 still no working decimal point
edit 22/01: update 3.13 stIll NOT working! Copy/paste from i.e. calculator or a note is also a no go for me 😞
edit 05/02: update 3.14 it’s working again! Had to select the app in the store to find the update, but it’s alive again.
12-15-2019 22:39
12-15-2019 22:39
Problem not solved for me either. Got the latest update, the bug still exists. iOS 13.3, Fitbit 3.12
12-16-2019 21:15
12-16-2019 21:15
That’s not an acceptable solution. Why would I want to go to two places to input to Fitbit ... model and web app?
I’m only inputting it manually in the first place because my Aria isn’t working and I’ve gone to an alternate supplier.
12-17-2019 01:05
12-17-2019 01:05
Yep I’m having the same problem. Updated to Fitbit app version 13.12.1 and firmware version 22.58.0 (on iOS 13.3).
