04-15-2018
12:32
12:08
MarcoGFitbit
04-15-2018
12:32
12:08
MarcoGFitbit
I can not connect Charger HR with my phone. it normally worked, and then I stopped using the fitbit and now I can not connect it. I have both Wifi and Bluetooth turned on. Any advice? I am desperate
Best Answer04-17-2018 12:36
04-17-2018 12:36
Hello @Andenka, thanks for joining the Fitbit Community, it's great to have you on board. ![]()
Thanks for bringing this to my attention. Is your tracker not syncing with the app or is not possible to set it up? Have you restarted your tracker and your phone lately? If so, I would like to suggest you the following:
If your tracker is not setting up correctly, I would like to recommend to follow these steps:
I hope this can be helpful, give it a try and keep me posted in case you need anything else.
