04-18-2017
18:43
09:15
MarcoGFitbit
04-18-2017
18:43
09:15
MarcoGFitbit
Just got a new iphone 7 but Fitbit charge HR won't connect to it fully. Meaning I get the code to connect to show up but once it's entered on the app it just has an error pop up after trying to connect for about a minute. Any ideas?
04-19-2017 09:51
04-19-2017 09:51
Hello @Simonson23t, thanks for joining us, it's great to have you on board!
Have you tried to restart your Charge HR lately? If so, I'd like to suggest the following:
I hope this can be helpful, give it a try and keep me posted in case you need anything else!
04-26-2018 22:16
04-26-2018 22:16
Hi there,
I have used all of the above advice and my FitBit is still not connecting to my iPhone. It seems to just stay on the same screen with the number code, saying "connecting to FitBit" with nothing happening.
If there is some other advice that could help me that would be great.
04-30-2018 05:00
04-30-2018 05:00
Hello @MS13, have a warm welcome to the Fitbit Community, it's great to have you on board.
I appreciate you have already tried the troubleshooting steps I've provided earlier, if the setup process is getting stuck after you have input the 4-digit code, please force-quit the app by double tapping the home button on your phone and swiping up the app, then open the app again and go to Account and check if your tracker has already been added to your account. That exact same issue has happened to me and when I force-quit the app, I find the tracker has already been added.
However, if the tracker is not listed under your name, please try to set it up again and let me know the outcome, I'll be happy to continue helping you.
04-30-2018 13:17
04-30-2018 13:17
05-01-2018 05:47
05-01-2018 05:47
Hello @MS13, I hope you're doing well, thanks for taking the time to reply.
Indeed, if under your name you're only able to see "Set up a New Device" that means the tracker has not been added to your account. As you have already tried the troubleshooting steps I've provided above, I would like to follow these steps in order:
I hope this can be helpful, give it a try and let me know the outcome.
