03-16-2017 19:18
03-16-2017 19:18
The app is not showing food and water intake which was updated by me for all the days .
03-16-2017 21:04
03-16-2017 21:04
I'm having the same issue! And the. After midnight it takes away ALL my meal info for the week!
Best Answer03-17-2017 00:09
03-17-2017 00:09
I'm having a similar issue. Every time I update the water / food it changes all the past food / water values to the same.
Best Answer03-21-2017 07:34
03-21-2017 07:34
Hello @Shilpa24, @LaTDPSB and @JoG1, have a warm welcome to the Fitbit Community, it's great to have you on board! ![]()
Since when are you experiencing this situation? Are you only able to see information about water and food for "Today"? If so, please tap on each tile to verify that the logs from previous days are still showing. The Fitbit app only displays the information for "Today", if you swipe on the app, only the main tile (steps, calories burned, distance, active minutes and floors) will show previous days's information, this is the normal behavior of the app. To check information from previous days, please tap on each tile, where you will find detailed information from previous days and a graph that will let you compare previous days, weeks and months.
If after tapping each tile, the information is not showing, please go to your online Dashboard and check if the information is displayed there. If it is, it's possible the Fitbit app is not updating the information correctly and for that I would like to recommend the following:
I hope this can be helpful, give it a try and keep me posted in case you need anything else!
Best Answer03-22-2017 02:49
03-22-2017 02:49
I tried disconnecting, restarting, logging out and back in and restarting my phone but the daily calories are still at zero. They are not being pulled in from Lose It App.
Best Answer03-22-2017 05:52
03-22-2017 05:52
Hello @Ndorrien, thanks for joining us, it's great to have you on board. ![]()
If the calories are not syncing correctly from Lose It! to Fitbit, my suggestion would be resetting the connection between them. To do this:
I hope this can be helpful, give it a try and keep me posted in case you need anything else! ![]()
Best Answer06-05-2019 12:09 - edited 06-05-2019 12:28
Same issue, but also not showing active hrs. Deleted app, forced close, cleared cache, nothing worked. Also restarted phone.
