04-19-2016 15:11
04-19-2016 15:11
04-19-2016 15:53
04-19-2016 15:53
05-03-2016 21:10
05-03-2016 21:10
05-10-2016 16:22
05-10-2016 16:22
I am also having trouble with the app calculating water consumption. I put in the amount but it doesn't update, even if I close the app out and restart. I am on an iphone 6s. Any comments FITBIT?? This is not a recent occurence.
05-11-2016 12:45
05-11-2016 12:45
would be nice to input the amount yourself
05-11-2016 13:36
05-11-2016 13:36
@suki Does restarting your iOS device help? Also, are you able to see your logged water on your Fitbit.com dashboard? Keep me posted!
@SunsetRunner You can input the amount of water you drink. This can be don by: clicking the water tile on your dashboard > click the + icon in the top right-hand corner > plugging in the amount of water you drank at the top and then click save in the top right-hand corner.
05-16-2016 12:34
05-16-2016 12:34
Hi. I have not tried restarting the device. It's a minor annoyance since I can figure out how much water I've had in my head, but the water calculation has worked correctly in the past. I can see the water logged in, on the dashboard, every time I input, it just doesn't add the water up. So for instance I have had 24 oz. then log in 12 oz. it will stay at 24.
05-18-2016 12:51
05-18-2016 12:51
I'm having same problem for last 3 days. Put in water 1000ml and all is fine. When I put in next 500ml, it doesn't show and then it gives me -500ml. Mostly it's just annoying.
05-21-2016 05:33
05-21-2016 05:33
It has been acting worse in the past few days, for me. I'm glad I'm not alone. Fitbit probably needs to address this. Restartiing the device every time you add water is not a solution!
05-30-2016 21:21
05-30-2016 21:21
06-09-2016 14:35
06-09-2016 14:35
Having issues as well. The water history in the app is correct, but the total is incorrect. Happens intermitently, about every couple of days. When I look at the dashboard on this website it shows the correct total. Interesting thing is you can actually see it happen. Hit the quick add, the total increases, bar on graph increases, then like a second or 2 later you can see the bar drop back down and the total is back to the previous one.
06-09-2016 17:43
06-09-2016 17:43
