07-23-2017
07:23
10:00
MarcoGFitbit
07-23-2017
07:23
10:00
MarcoGFitbit
I have tried all of the various suggestions posted to try to connect my brand new Alta HR to my iPhone7 via Bluetooth. It still will not connect. Very frustrating!
08-21-2018 05:37
08-21-2018 05:37
Hello @Ciarand, thanks for joining the conversation, it's a pleasure for me to welcome you to the Fitbit Community.
I appreciate you have let me know you have already tried the troubleshooting steps I've provided earlier. Tell me, which tracker are you currently using? Which iPhone model are you using to set up your Fitbit device? Have you updated the OS on your phone and the Fitbit app recently? Which other troubleshooting steps have you tried so far? This information will be very helpful for me to determine what should we do next.
Thanks for your patience and understanding, I'll be waiting for your reply.
07-24-2017 10:17
07-24-2017 10:17
Hello @jacomijntje, it's a pleasure for me to welcome you to the Fitbit Community, I hope you're having an excellent day.
Please keep in mind that the Fitbit trackers do not sync directly through the Bluetooth on your phone, they use the Fitbit app to connect and sync with it. If your Alta HR is not able to pair to your phone, please restart it and leave it plugged in, making sure it's charging. Then, restart your iPhone, update the Fitbit app if necessary and try to set up your tracker as a new device once again.
To set up your tracker as a new device:
I hope this can be helpful, give it a try and keep me posted in case you need anything else!
08-20-2018 14:24
08-20-2018 14:24
This doesn't work 20/8/2018
Why is this happening and when are yous sorting this out
08-21-2018 05:37
08-21-2018 05:37
