12-07-2023 10:48 - edited 12-07-2023 11:40
The monthly RHR (Resting Heart Rate) average does not add up. For example, if I took the month of June, and added up my RHR using the data for each date, it would average to about 58. However, because the last week of the month was averaging 64, it shows the whole month as 64! Same with last December, where it literally made up a number (70) for the monthly average that was about 9 higher than it should have been. In months, where there are no spikes at the end of the month, it seems to calculate correctly.
I have now checked in both the Android and iOS app, since I have both phones. Same issue.
This problem predates the current version of the app, if that helps.
Please help!
Best Answer12-07-2023 11:41
12-07-2023 11:41
From the Android app, but iOS shows the same too
The data points from Dec 1 - Dec 31, 2022 are:
60, 60, 59, 59, 58, 58, 59, 58, 58, 58, 58, 58, 58, 58, 58, 57, 58, 60, 61, 63, 65, 67, 66, 66, 66, 67, 67, 68, 71, 70, 69
That averages to 61 (rounded down, as Fitbit seems to do).
Best Answer12-07-2023 12:19
12-07-2023 12:19
From the Android app, but the iOS app shows the same
The data points from Jun1 - Jun 30, 2023 are:
58, 57, 57, 57, 57, 57, 57, 57, 58, 60, 62, 60, 58, 58, 59, 60, 60, 62, 63, 64, 65, 65, 67, 65, 65, 66, 65, 64, 65, 65
Best Answer12-07-2023 12:20
12-07-2023 12:20
The only "algorithmic mistake" I can see is that if the month overall is low and then it trends high during the last week, the Fitbit app just uses the last few days. In fact, if you look at the Dec data (in one of the above posts), even the last week was not 70 as an average
