@nb9bob welcome to the forums! Yikes, that sounds pretty odd. I recommend restarting your Fitbit SUrge by doing the following:
After the restart, charge your Surge. Keep in mind that charging completely takes one to two hours. Also, because battery life is affected by use and other settings, actual results may vary. These tips might help when you want to prioritize battery life:
Let me know how it goes after verifying all these steps. ![]()
Did you receive the answer you were looking for? Mark the post as an accepted solution! 🙂
