03-27-2024 18:24
03-27-2024 18:24
How do I change my goal for water intake? I’ve lost weight and my goal is half of my body weight in ounces, but I can’t figure out how to reduce it!
Best Answer03-27-2024 23:21
03-27-2024 23:21
Hi @BevSigns2 - in the Fitbit App, click on the water tile and then the gear icon, to change the goal.
Best Answer03-28-2024 03:52
03-28-2024 03:52
@BevSigns2 The path suggested by @Guy_ is incorrect. Please tap on the You icon in the lower right. In the Goals section, you can tap on See all or swipe left to Nutrition. Tap on Water, change your goal, the tap on Set goal.
Laurie | Maryland
