12-04-2017
10:02
06:27
MarcoGFitbit
12-04-2017
10:02
06:27
MarcoGFitbit
iPhone and Charge 2 won’t connect on Bluetooth
We need a bit more info, is this a new phone. Did you have it hooked up to your old phone. You have to remove your Fitbit from your old phone before it will recognize your new phone.
ALAN | VAN,B.C. Canada Community Council Member
Versa, Charge, Charge HR, Ionic, Ace, Aria 2 scale, Flyer headphones - iOS
Click here Fitbit help for more solutions
Hello @Gazzahoss, have a warm welcome to the Fitbit Community, it's great to have you on board.
, it's also nice to see you @ACG, thanks for your help with this matter.
@Gazzahoss, please keep in mind that your Fitbit tracker does not sync directly through the Bluetooth on your phone, it uses the Fitbit app to do it. If you're able to see your tracker on the list of paired devices on your phone's Bluetooth that might be because Notifications or All-day Sync have been enabled.
If your tracker is having trouble syncing, please try the following:
If your tracker is still not syncing correctly, let's try adding it as a new device to reset the connection between the tracker and the phone. Don't worry, none of the information previously stored in your account will be deleted.
To set up your tracker as a new device:
I hope this can be helpful, give it a try and keep me posted in case you need anything else. ![]()
