05-05-2021 14:05
05-05-2021 14:05
Ionic had 77% charge and just quit when I tried logging biking activity for the first time. Will not restart even after a charge. Sounds like a common problem.
05-06-2021 11:28
05-06-2021 11:28
Welcome to the Fitbit Community, @Muckabucka.
Thanks for the details shared in your post and for already trying to resolve the issue. I understand your concern and recommend following the complete troubleshooting tips in Why isn't my Fitbit device's battery charging?
Hope this helps.
05-06-2021 15:46 - last edited on 05-06-2021 17:26 by LiliyaFitbit
my battery ran out of charge and I’ve tried everything and it will not restart or charge. It’s been over a week and I try it every day. This happened once before after an update and it would not start for 3 days then just came back on. What is going on???
And FYI before you tell me to use the trouble shooting fixes they don’t work at all ! I’m very unhappy this watch is only just over a year old. I can even use the factory reset as it won’t turn on. Help
Moderator edit: format
05-06-2021 17:30
05-06-2021 17:30
It’s good to see you in the community, @Soccerlorraine.
Thank you for joining the thread and sharing the details of the issue with your watch. I understand how you are feeling about this situation and appreciate your troubleshooting efforts. The best way to get help for this problem is to chat with our Support team online or give them a call. They will evaluate your device's behavior and help you with this matter. Click here to get connected.
See you around.
