09-29-2023 06:17
09-29-2023 06:17
I’ve been tracking my sleep with Fitbit for 3-4 years now. For about 2.5 weeks in September, my sleep score went from an average of 84 to an average of 90. I thought I must be sleeping better, though I really didn’t notice anything changing in my sleeping habit. I also thought maybe something had changed with Fitbit. In the last week or so, my sleep score went back down to average, even though, again, I have detected no change in my sleeping pattern. The last two nights, Fitbit claims I have had virtually no deep sleep! This cannot be, as I fell asleep immediately as I always do and do not remember waking up til morning. Another problem that happens occasionally but has been happening more lately, including the last few nights, is the time I get into bed or fall asleep is indicated about an hour later than I actually went to bed and/or fell asleep. I know how to edit the log, but it’s very strange what happens then. Before, it would almost always indicate that in that first hour I was in deep sleep. Huh?? It originally said I wasn’t even in bed. The last two nights, though, when I edited the log, it said I was awake or in light sleep and, as I mentioned before, claims I got no deep sleep. What is going on??
10-01-2023 09:29
10-01-2023 09:29
I'm experiencing the same thing! I went to bed early last night and slept in, and my tracker claims no deep sleep, inconsistent readings, and only 4 hours of sleep.
10-12-2023 13:49 - edited 10-12-2023 13:50
Same. Except mine is a Fitbit Inspire 2. If I try to add a sleep log for the missing hours, it just adjusts the original log to a shorter time.
10-12-2023 18:31
10-12-2023 18:31
10-16-2023 07:33
10-16-2023 07:33
My inspire 2 has stopped tracking my sleep,too and nothing here has helped
10-17-2023 10:42
10-17-2023 10:42
My Inspire 2 also has stopped tracking my sleep. What is going on??
10-17-2023 12:58
10-17-2023 12:58
Hi Everyone. Welcome back and good to see you participating for the first time in the community new users.
Thank you for providing the details regarding the inconvenience with heart rate.
When your body is completely at rest and you haven’t moved for about an hour, your device should record that you’re asleep. Before considering other options, please keep in mind that there are some factors that may prevent your tracker from recording your sleep. Please make sure of the following:
If you haven't done so already, please restart your device.
In addition, please wear your device on your non-dominant hand and monitor it for the next few days. In the meantime, for the nights that don't have sleep data, you can manually log your sleep by going to the Fitbit app, tapping on the "+" icon next to the sleep tile > Add Sleep Log and entering your details.
10-22-2023 12:21
10-22-2023 12:21
Same. I was hoping to find some answers here, but no luck so far.
10-22-2023 14:14
10-22-2023 14:14
10-22-2023 15:13
10-22-2023 15:13
It seems like if I have a potty run, which I usually do around 3AM, Versa2 decides okay, she's up, even though I go back to sleep for 4 more hours. It's kind of ridiculous.
10-23-2023 00:13
10-23-2023 00:13
Same issue with my Inspire 2.
10-23-2023 21:06
10-23-2023 21:06
Hi my inspire 2 stopped logging any sleep data at all since the beginning of 2023. I've been researching and trying all suggestions but no data appears at all. Should I reinstall the app? What else can be the issue?
11-17-2023 08:18
11-17-2023 08:18
Same issue. I've done everything...rebooted, reinstalled the app, cleared all user data, ensured hr on, sleep mode off. It's just broken. I'm returning mine.
12-09-2023 07:51
12-09-2023 07:51
I have FitBit Versa 2. Mine recently started to do the same thing. At one time I was able to go change it manually but not an option now. I’ve had other issues and they all seemed to have started when they made the switch to Google. Frustrated. 😡
12-09-2023 08:23
12-09-2023 08:23
After a whole year of no automatic sleep data, my Inspire 2 suddenly started working on 12/3/23. out of the blue it seemed. It is quite impressive amount of data and I'm thrilled it's working. But other than turning feature on and off and on again I didn't do anything different. Wonder if they installed an update or something that shook things around!
12-09-2023 12:55
12-09-2023 12:55
12-23-2023 06:47
12-23-2023 06:47
My Versa 2 seems to be scoring my sleep much lower than it always had. I will get over an hour of deep sleep, good amounts of REM and light sleep and be awake cumulatively for less than an hour, which for me is great, and get a score in the 70's where it used to be in the 80's comparing apples to apples. It seems like it changed when Google took over. I was excited when I first found out that there was a good smartwatch that utilizes the Fitbit app and platform. I will definitely not be getting the Google watch and now I feel like they "broke" the Fitbit aspect. Too bad they didn't leave well enough alone.
12-30-2023 08:08
12-30-2023 08:08
I had previously been using an Inspire 2, for about three years, which began having problems with sleep tracking: some nights tracking ok, some nights no tracking at all, many nights cutting off if I got up to go to the bathroom. Sometimes I could edit the log and magically all the data appeared for a score, other times the data was missing for the second half of the night. I finally thought I needed a new device and purchased an Inspire 3 this month. My first night using this brand new Fitbit the VERY SAME THING happened!! Sleep tracking until I got up for one minute to go to the bathroom and then went immediately back to sleep. Only the score for the first segment was recorded. I edited the log and the rest of the data appeared. What on earth is wrong with your trackers????? This is obviously a product issue for SO many users!!!! Get a fix together for us and stop telling everyone to reboot (I did). If buying a new device does not result in better tracking the problem is the product! I am very very disappointed. Is my only solution to return my new Inspire 3 and switch to a more reliable tracker?
12-30-2023 14:05 - last edited on 01-27-2024 05:06 by ManuFitbit
I'm still having issues. I certainly won't both with my premium membership
as the tracking device itself is not reliable enough.
*I acknowledge the traditional custodians on whose lands I live, learn,
play and work. I pay my respects to all the Aboriginal Elders who protect
the memories, traditions, cultures and futures of their people.*
Even after the latest upgrade, there's no improvement with sleep recording on my Inspire 2. I've had to add a sleep log in three different parts for last night, so the sleep score is split too. For one stretch of from 1.49 to 5.05am , it says I was awake for only 11 minutes, but asleep for only 1 hr 7 minutes. What happened in the other two hours? Hopeless....
