A lot of women use OPKs or Fertility Monitor to predict ovulation. Please make an option to change your ovulation day. There should also be a way to omit a cycle from the Average or trends screen in the case of miscarriage simce there is also no where to notate a positive pregnancy test to show pregnancy on the calendar.
1. Make ovulation day editable
2. Add miscarriage option to omit that cycle from the trends screen.
3. Add positive or negative pregnancy tests options.
4. Show pregnancy in the calendar with weeks count down if pregnant.
Moderator edit: Clarified subject and Labels
Community Guidelines
Learn the Basics
Join the Community!
Go to the Help Site
Contact Support
