02-10-2024 08:24 - edited 02-13-2024 08:26
Has anyone managed to get Cluster Storage working for sharing data between 2 apps/clocks?
Can they share an example and confirm that the sharing is done at the watch level.
It should be noted that normally each clock/app has it's own private watch storage which possibly suggests that there must be some public watch storage which can be used for sharing.
02-13-2024 15:24
02-13-2024 15:24
Maybe:
import * as appClusterStorage from 'app-cluster-storage'
const cluster = appClusterStorage.get('gondwana')
console.log(cluster) // should be [object Object]
cluster.setItem('testKey', 'testValue')
const testVar = cluster.getItem('testKey')
console.log(testVar)
I have no way of testing this, since I don't have any relevant watches and I suspect it isn't implemented in the sim.
02-12-2024 21:19
02-12-2024 21:19
Do you mean Cluster Storage? If so, the data would be shared among multiple apps/clock faces via smartphone. I'm sorry I don't have its working example though.
02-13-2024 07:27 - edited 02-13-2024 07:28
Thanks @r.b - I do mean App Cluster storage.- when I tested it a while back there was no success.
In the package.json permission was requested and the following included
"requestedPermissions": [
"access_app_cluster_storage"
"appClusterID": "public",
"developerID": "<your developerID>"
but it doesn't seems to help - the instruction won't build as it has a syntax error
And no means is given to set the storage.
There seems also to be a confusion as to whether this is a companion feature, some say it is a watch storage and others a phone storage.
You probably need some import too like
import { appClusterStorage } from "app-cluster-storage";
But even then appClusterStorage is undefined.
Anybody have any ideas to try?
02-13-2024 13:37
02-13-2024 13:37
Two quick thoughts that probably won't help:
Re app-cluster-storage.get(clusterID: "public"), I know where you got that from. In JS, hyphens are subtraction so that's a documentation error.
02-13-2024 15:24
02-13-2024 15:24
Maybe:
02-13-2024 21:26 - edited 04-22-2024 00:03
Bingo! It works within an App.
This confirms it is on watch storage and no need for the companion and phone storage.
Curiously it causes the simulator to crash the watch, instead of not working.
Thank you, you are a Star!
04-21-2024 23:13
04-21-2024 23:13
@Gondwana- do you think appClusterStorage has something like appClusterStorage.addEventListener("change", () => {}); ?
It raises an error in the Simulator, may be only because cluster storage is not properly implemented or the syntax is wrong.
Hopefully there is some way of seeing if a change has been made to the storage?
04-21-2024 23:30
04-21-2024 23:30
I don't think Device SDK in sim implements cluster storage. Try a real watch. I can't because I don't have any left.
04-22-2024 00:02
04-22-2024 00:02
even on the watch it says expected a function
04-22-2024 00:04
04-22-2024 00:04
You could try setting .onchange directly. Total guess...
04-22-2024 00:17
04-22-2024 00:17
appClusterStorage.onchange = function() {
console.log(` detected a change.`);}
Doesn't get triggered when a change is made in the same app.
04-22-2024 00:36
04-22-2024 00:36
It's possible that it doesn't implement the LiveStorage interface.
But have you verified that your appClusterStorage var is of the right type? Eg, does it respond correctly to .setItem(), etc?
04-22-2024 01:00
04-22-2024 01:00
Yes it's working fine, but it means testing values to see if they change, so looking for a way to trap the change to improve it.
04-22-2024 02:05
04-22-2024 02:05
If you can't attach an eventListener, why not wrap the update in a function checking the getItem against newValue after having set?
04-22-2024 13:15 - edited 04-22-2024 13:17
@SunsetRunnergot me thinking about this...
Since only one app can be running at any one time, an app should only need to check for changes made by other apps when it starts. App B can't change storage while App A is running. Internally, App A can communicate its own storage changes using other means. So it may not be necessary for cluster storage to have change events on the device.
I probably didn't explain this well, and I could be wrong.
