09-08-2020 12:11
09-08-2020 12:11
Good evening:-)
My daughter has an Ace 2. We set it all up without a problem & under my username & the app is on her iPad has always worked fine until now.
The app logged her out & now I can’t get back in using my log in details.
I’ve tried to reset the password but it just keeps telling me something went wrong.
I’ve also deleted and reinstalled the app & it’s still not letting me log in.
Any ideas please? It’s not much fun when she doesn’t have the app to check her stats on.
Thank you,
Emma 🙂
Best Answer09-09-2020 14:29 - edited 09-09-2020 14:31
Welcome to the Fitbit Community, @Emzo82.
I am sorry to hear you can't log into your Fitbit account on your daughter's iPad in order to check her stats. Thanks for trying to resolve this, I appreciate the additional details and I am here to help. I understand how you are feeling and would like to confirm if you're able to log into your Fitbit account using another device/phone or fitbit.com web dashboard? I recommend trying the following:
1. Force quit the app and check if it is updated to the latest version by following these steps.
2. Restart the iPad.
3. Try to log in to your Fitbit account and switch to kid view.
Looking forward to hearing back from you.
Best Answer09-10-2020 14:33
09-10-2020 14:33
Hi!
Thanks for getting back to me.
I can log into my Fitbit account & switch to kid view with no problem. It shows no stats though on the kid view & says device can’t be found.
I can’t log into the app on her iPad. The account details are the same as mine but it says it’s not right.
Does that help at all?
Thanks
Emma
Best Answer09-11-2020 14:16 - edited 09-11-2020 14:19
Hi @Emzo82, thank you for your reply.
I am sorry to hear the issue persists, I appreciate your efforts and the additional details. I recommend turning off WiFi and using cellular data to log into your Fitbit account on iPad.
Regarding the issue with syncing, please try the following on your device:
Keep me posted on the outcome.
